Canadian Forum Canadian users, post event and club info here.
size 1987 N/A
Old Apr 21, 2008 | 10:26 AM
Xtreise's Avatar
size 1987 N/A
Hi everyone, does anybody know the size of a bolt I can use to block the hole where my Tempature sensor is, I don't want to loose all my coolant while trying to figure out the adapters thingy when I'll be installing an electrical temp gauge.
Old Apr 21, 2008 | 06:18 PM
Sizzlenut's Avatar
Fortified.
Whatever you do, don't put a bolt in there. It's a 1/8 NPT pipe thread, far different from any bolt. Your new temp guage probably uses the same thread.
Old Apr 21, 2008 | 06:30 PM
Nismo Convert86's Avatar
400WHP or bust
I'm fairly sure it's not NPT, I think it's British Standard Pipe Thread/Taper same size, but one TPI off I believe it's 27 instead of the 28 on the NPT.
Old Apr 22, 2008 | 09:04 AM
Aaron Cake's Avatar
Engine, Not Motor
The pipe thread on the temperature sensor can be random at times.
As Nismo said, sometimes it is 1/8" BSPT. Early engines tend to be BSPT.
Later engines are a straight metric pipe thread.
Sometimes it's been hacked up so much it's now 1/8" NPT.
Old Apr 22, 2008 | 06:30 PM
Sizzlenut's Avatar
Fortified.
I've used my 1/8NPT27 tap several times with no issues.
Old Apr 23, 2008 | 08:37 AM
Aaron Cake's Avatar
Engine, Not Motor
Yes...The thread is close enough to 1/8 NPT that it will conform.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
mulcryant
Sep 9, 2015 05:24 PM
