Does Icemark still do wiper switches?
Old Apr 16, 2008 | 08:57 PM
martha_91's Avatar
My RX7 made me a mechanic
I pm'ed Icemark about the wiper switch relay issue for my s5 (with front and rear wipers - only 'I' speed works: no intermittent or high speed) as well as email the webmaster of his website last week and never got any replies. Mazda quoted me $700 sumthin for the whole switch and no scrapyard around here have one....
Can anybody (including Icemark himself) be able to help me out with this?
Old Apr 16, 2008 | 09:09 PM
Craiger's Avatar
If you were in the states I think there is a chance he'd do it for you but I think he had some bad expirences with Canadian customs looseing the parts he shipped.
IIRC he has a good DIY writeup on his website that is easy to follow. If it's not there then there is a good writeup in the archives here. I did mine myself following the instructions and it worked out great.
Old Apr 16, 2008 | 09:13 PM
dean23's Avatar
pwned
he sells the unit as a whole.... last time i checked atleast
Old Apr 16, 2008 | 09:15 PM
martha_91's Avatar
I have a soldering gun but no real good experience with it... I don't need any replacement parts to do it? I just have to resolder it all?
I glanced at the DIY write up but I was time pressed at the time.
PS I'm driving from Florida back to canada with a cube van on the weekend of the 25th of april
Old Apr 16, 2008 | 09:24 PM
Craiger's Avatar
You might be able to get away with just re-soldering it but more than likely you'll want to replace 2 relays (only one if you have no rear wiper). You can get them from digikey, i think mine were about $20 shipped. You should also buy a 20-30 watt soldering iron for this kind of work, they will run you about $20 too, and you'll need some de-soldering braid and some flux core wire solder.
Old Apr 16, 2008 | 09:26 PM
martha_91's Avatar
digikey?
Old Apr 16, 2008 | 09:51 PM
Craiger's Avatar
http://search.digikey.com/scripts/Dk...l?name=Z950-ND
I am 99% sure that is the correct part number.
Old Apr 17, 2008 | 04:08 PM
martha_91's Avatar
thanks man
Old Apr 17, 2008 | 04:09 PM
martha_91's Avatar
no hassle at the border when u imported?
