Fuel Pressure Question
Old Apr 16, 2008 | 04:17 PM
HKSpoweredFC3S's Avatar
Custom User Title
Question Fuel Pressure Question
How much fuel pressure do I need to have with factory - 12psi of boost?
bassically just tell me the factory setting of fuel pressure please =]
Old Apr 16, 2008 | 06:42 PM
AlexG13B's Avatar
brap brap brap
36 psi iirc
Old Apr 16, 2008 | 09:33 PM
Custom User Title
k thanx.
Old Apr 16, 2008 | 09:39 PM
dean23's Avatar
pwned
i run ~42psi
Old Apr 17, 2008 | 04:56 AM
HAILERS's Avatar
HAILERS
At zero psi, the pressure should be 35.6 to 37.0 psi. For each psi of boost you add one psi to the 37psi figure. As in 37psi plus 12psi.
You get to zero psi by just removing the vacuum hose from the FPR and plugging the vacuum line momentarily. Or for that matter you could just turn the key to ON, engine off to achieve zero psi.
There's a free online FSM available that shows the fuel pressure.
Fuel pressure at idle with everything connected up should read 28psi ...give or take a bit. I see 31-32 psi at idle.
Rotospectre
Mar 28, 2018 03:33 PM
