What clutch setup are most of you single turbo guys running?
Old Apr 26, 2002 | 08:38 AM
1point3liter's Avatar
Twin Turbo LSX
I'm getting my car ready fot a single turbo. When my setup is complete, I'll be producing aproximately 450rwhp. What clutches have you guys had good luck with. I'd prefer to keep a sprung hub to be a little easier on the drivetrain. Currently I'm considering a clutchmaster's stage 4. Anyone running one of these?
Also I need to order a lightened flywheel. Any insight on what's going to be the best for my application? I've thought about a 8.5 or 9.5 wheel. I don't drive the car daily, but I do ocassionally get stuck in traffic. I'm not a drag racer really, but I do get in the ocassional stoplight battle. I do play from a roll a lot.
btw, my car currently has a clutchmaster stage 1 which I don't think is going to cut it any more. Is just getting a disk and using that pressure plate an option?
Thanks in advance!
Bryan
Old Apr 26, 2002 | 03:30 PM
I'm running what most people love to hate, THE CENTERFORCE DUAL FRICTION and it's been working find for about a year. I only have 300 FWHP, maybe the guys with over 400 FWHP are having problems with this clutch.
Old Apr 26, 2002 | 04:17 PM
voodooracing's Avatar
be aware that the centerforce for the FD is not Dual Friction.... there was no room to fit those little weights on the pressure plate....
to hold 450whp, you could use a ACT setup, or if you don't mind to spend big bucks, some twin plates are very streetable and hold big hp.
If you are considering doing drag racing, may be a lighten flywheel may not be the best upgrade.
Old Apr 26, 2002 | 05:49 PM
RETed's Avatar
Uh, "dual friction" has nothing to do with the inertial weights on most Centerforce clutch systems.&nbsp The "dual friction" describes the design of the clutch disc that uses two different materials on either side of the clutch disc.&nbsp The FD dual friction unit is a true dual-friction disk, therefore there is no false claims by Centerforce on their part.
-Ted
Old Apr 26, 2002 | 08:04 PM
Cheuk in Seoul's Avatar
ACT street / strip clutch and 9.5# flywheel... package deal from SR.
No problems holding 400+ RWHP
Old Apr 27, 2002 | 01:29 PM
user 84205's Avatar
OS TWIN PLATE
Old Apr 27, 2002 | 02:46 PM
yy4u's Avatar
Bonez street/strip clutch, i believe the same one, Ari and the guys at rx7.com are running, but i may be wrong on that fact.
Old Apr 27, 2002 | 09:30 PM
Silver7's Avatar
I'm using the ACT Xtreme PP with street disc. So far it's holding up well but the true test will be when I take it to the strip.
Old Apr 27, 2002 | 09:32 PM
Poweraxel's Avatar
ACT extreme
Old Apr 27, 2002 | 09:38 PM
Directfreak's Avatar
I am a Jeeper Now.
I just bought from a sponser here..
BNR Supercars clutch pageBNR Supercars clutch page
Supposedly good for at least 450 hp
sherff
Feb 24, 2019 12:09 PM
armans
Aug 15, 2015 09:08 PM
Turblown
Aug 14, 2015 04:48 PM
