Rotary Drag Racing The place to post your racing stories and info
Brand New design for axle assemblies
Old Apr 5, 2008 | 06:21 AM
ErnieT's Avatar
Living life 9 seconds at a time
Hey guys, since I have seemed to break everything including the axle upgrade from driveshaft shop, I had them custom fab a whole new setup for the FD!* It includes everything level 5 33 spline, you name it, its all replaced.* Price is $1900, but worth it imo
Old Apr 5, 2008 | 09:55 AM
zinx's Avatar
_________________________
Very nice! I'm going to ride out this season and see how my current axles treat me and then consider these.
Old Apr 5, 2008 | 10:04 AM
ultimatejay's Avatar
Why dont' you just buy a stronger rearend? How much have you invested in all these axles so far? You could have put a Ford 9" in your car for about 2000-2500 bucks and be done with breaking axles.
Old Apr 5, 2008 | 11:10 AM
RoTaRyBoYz's Avatar
InsaneRotaries.com
^ If he put in a solid rear or any other rear for that matter, then he will not be legal for some classes... These cars are built around a specific set of rules for that specific class, so any changes that's not in the rule book automatically makes the car illegal in that class..
Old Apr 5, 2008 | 02:27 PM
ErnieT's Avatar
^^ As stated, Its easy just to put a 9" rear in, but that would bump me out of the street class.
Old Apr 5, 2008 | 04:21 PM
2Lucky2tha7's Avatar
Back at it again!!
^^Hopefully I'll be able to see your car at the track sometime soon. I wanna see it run in person.
Old Apr 5, 2008 | 09:17 PM
Ok, now I understand. I was like man this guy likes to throw money away. hehe.
Good luck on the new axles. Hope they work out for you this time.
Old Apr 5, 2008 | 09:35 PM
justturbo2's Avatar
Registered User
nice pieces ernie. do they have more in stock. or is this the first set that is being tested
Old Apr 6, 2008 | 08:44 AM
ErnieT's Avatar
I believe they made a batch, not just a one set. Give them a call.
Old Apr 6, 2008 | 02:20 PM
SPEED_NYC's Avatar
RX-Parts
when i call should i ask for the ernie spec axles?
Old Apr 6, 2008 | 03:53 PM
ErnieT's Avatar
No, "***** Out Specs".......
Old Apr 6, 2008 | 04:26 PM
4rotores's Avatar
"el father"
Thumbs up axles
nice set up whats the phone number or website for that company?
Old Apr 6, 2008 | 05:46 PM
ErnieT's Avatar
http://www.driveshaftshop.com/
Old Apr 6, 2008 | 10:03 PM
4rotores's Avatar
"el father"
thanks man.
Old Apr 7, 2008 | 09:40 PM
crispeed's Avatar
'Tuna'
So did they change the size/spline count on the stubs that go into the diff? That would also require a different spider gear setup for the diff. I hope the material type was upgraded. If not then the weak link is still there. The outer hub is basically the porsche setup so that's a plus although most of the cars I know pulling 1.3 60ft's with IRS don't really break the factory outer stuff but mainly the inner.
Old Apr 8, 2008 | 12:58 AM
ErnieT's Avatar
No thats the same. They asked me if I wanted that and I said no, because of the extra work involved on my end.
Old Apr 8, 2008 | 08:02 AM
blitzboy's Avatar
Do they do just uprated inner stubs to fit the standard axles ?, as I have just bought some 300mm axles already
Old Apr 8, 2008 | 11:52 AM
crispeed's Avatar
'Tuna'
That extra work can make the difference between breaking on every pass. Is much less work to change/upgrade a weak link in the beginning than to be continously swapping out weak parts.
Are the inner stub/cv made out of 300m?
Old Apr 8, 2008 | 02:20 PM
RX794's Avatar
NYC's Loudest FD
Would they be able to make the parts for this now? Like as an option?
Old Apr 8, 2008 | 04:21 PM
ErnieT's Avatar
Dunno. Give them a call.
Old Apr 8, 2008 | 04:28 PM
LETHAL RX7's Avatar
The inner is a standard spline/style but uses a 300m material. The shafts are a larger spline also i think he said 35-36 spline and the outters are a porsche type.
Greg
Old Apr 8, 2008 | 05:01 PM
crispeed's Avatar
'Tuna'
For the serious dragracer then the easiest way to upgrade the inners would be with a spool. For the rest that use the stock type housing/LSD etc. the stock size would have to surfice.
Old Apr 8, 2008 | 05:22 PM
ErnieT's Avatar
Still, its a much better option then we had.
Old Apr 8, 2008 | 07:23 PM
enzo250's Avatar
IRS Champion
Looks very Nice Ernie!!!
Old Apr 8, 2008 | 07:24 PM
enzo250's Avatar
IRS Champion
I've got a set coming to me as well with billet ford inners going into a strange spool... hehe...
