Haltech How to view/log actual AFR's instead of voltage
Old Mar 27, 2008 | 03:16 PM
zbrown's Avatar
So i sold my old wideband and bought a AEM just so i could have the linear 5v out, I want to log and view actual AFR's instead of stupid raw voltage. What do i have to do??
No matter what setting i try it only displays the voltage not the AFR,
I have the o2 type as "Calibrated UEGO" and have the sensor voltages calibrated to the corresponding AFR's in the table when you calibrate the O2
So what gives, I really want to log my AFRs
And when i log like this, even though the ECU show 0-5volts, the log simulates it into a 0-1v graph
Or to make this work do i have to set it up on a spare A/D input??
Thanks alot
zac
Old Mar 27, 2008 | 04:32 PM
slo's Avatar
slo
registered user
which haltech, which firmware/software
Old Mar 27, 2008 | 08:18 PM
zbrown's Avatar
Man i am an idiot some times.......... E8 1.62
I now have the linear O2 output tied into a spare A/D and the O2 input
works perfect........... logs are perfet.......... YEAH
Old Apr 3, 2008 | 11:57 AM
Comitatus's Avatar
Down for the count...
Wait...what did you do?
Old Apr 4, 2008 | 08:25 AM
zbrown's Avatar
I connected the O2 linear output to a Spare A/D channel and in the software you can set the input up for a wideband display
you can then pull a drop down and view true afrs, and log the true afrs in the log
I believe the very latest Firmware....... not even released allows you to do this on the regular wideband input and will show the true afr on the guage page instead of 02 voltage
just got it all working perfectly and i went to a boosted v8 and sold the haltech on the cheap
Einheri
Oct 7, 2015 12:23 PM
WANKfactor
Sep 29, 2015 01:14 PM
rattlehead
Sep 25, 2015 10:55 PM
