Power FC Under sensor check... What is wrong if it show fuel?
Old Mar 13, 2008 | 12:26 AM
FdRx728's Avatar
I just installed a supra tt fuel pump but have started the car yet. I checked the senors in my pfc and "fuel" is highlighted. It is showing 4.99 volts. Is this normal when changing a fuel pump or is something wrong?
Thanks
Jeremy
Old Mar 13, 2008 | 11:19 PM
cewrx7r1's Avatar
Eye In The Sky
The manual (did you read it) states on page 35:
[FUEL] ... Fuel Temp Sensor
Thus if yours is reading full voltage as it is, then either your sensor:
(1) has been pulled for an upgrade to a new secondary rail which the sensor can not be used with like in using the Bosch 1600s
(2) you have a bad sensor
(3) your sensor wiring has an opening in it
Skeese
65
Mar 28, 2017 03:30 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
