Where can I get these Bushings?
Old Mar 5, 2008 | 07:03 PM
zenofspeed's Avatar
Per Howard Coleman's VERY informative suspension post:
"The lower longitudinal link that absorbs all the braking and acceleration has a big fat rubber bushing in the front. It needs to be replaced.
The other set of bushings are the two at the top of the differential."
These bushings should be replaced with something much firmer. Where can I get JUST these bushings? Is there a vendor that produces them?
Thanks,
ian
Old Mar 5, 2008 | 08:03 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
ian,
various vendors sell a tubular replacement for the lower longitudunal link. it replaces the aluminum mazda link w a tube and rod end for the bushing. that solves bushing number 1.
i suggest you contact Energysuspension.com and ask them about the diff bushings. if they don't sell them perhaps if someone provided them the dimension they would make up a bunch.... they would have no problem selling them.
also, you could do the same w bushing number 1.
hc
Old Mar 5, 2008 | 10:32 PM
gracer7-rx7's Avatar
needs more track time
rx7.com
pettit
both offer poly diff bushings and heim jointed trailing arms and toe links
superpro makes poly bushings to replace both the diff and stock trailing arms. there is a group buy for tham from wanklin
Old Mar 6, 2008 | 09:10 AM
joe-c's Avatar
YOUR MOM IS MY ADDICTION
Veteran: Navy
where is mr.links when u need him lol
pfsantos
Sep 30, 2015 01:29 PM
