Haltech Fuel or ignition cut-off?
Old Feb 24, 2008 | 04:03 AM
RB_eater's Avatar
Leah Dizon > Roast Beef
What are the pros/cons of fuel versus ignition cut-off? I'm thinking ignition might be a safer bet but what do you guys think?
Old Feb 24, 2008 | 04:27 AM
RETed's Avatar
Try it for yourself...
The ignition cut is fricken' violent.
The fuel cut is a lot smoother.
-Ted
Old Feb 24, 2008 | 02:04 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
This is also very dependent on who you ask, some people say ignition cut some say fuel cut. I personally think that fuel cut is best, its what the OEM manufacturers use, and if you think about it logically this is how i see it:
Fuel cut, turns off the fuel completely thus literally shutting off the engine keeping it from reving any higher or running more boost. Spark doesnt do anything firing on its own.
But!
Ignition cut takes away the spark but the fuel keeps pouring into the eninge, when you turn the spark back on that fuel that is in the cylinder lights up and you probably get a premature explosion.
Then there's Soft Cut and Hard Cut, soft cut starts cutting fuel or ignition on one cylinder first, then 2, then 3 and so on, some people say this is the best way of doing rev limiting.
On the Haltech E8/E11 you have both options available to you, but we all know what can happen from cutting one rotor like the OEM.
Old Feb 24, 2008 | 11:25 PM
jacobcartmill's Avatar
just dont care.
ignition cut because it causes huge flames to shoot out of the exhaust
Old Feb 25, 2008 | 12:29 AM
mzrx7man's Avatar
sideways!!
lol nice! you ricer...
Old Feb 25, 2008 | 01:16 AM
just dont care.
haha i can't deny it. flat shifting with some huge flames is pretty cool!
Old Feb 25, 2008 | 03:27 AM
RB_eater's Avatar
I'm using the E6X has which both options so I guess I'll have experiement with them. I just wondered if there was any major downpoint to one or the other.
Thanks guys.
Old Apr 7, 2011 | 10:42 AM
RTY PWR's Avatar
i did my ignition cut at 5k, and the first time we did it, mad backfire and flames, but now, it just sounds like a regular 2-step with no backfire, any ideas? helpp
Old Apr 13, 2011 | 05:59 PM
haltechguy's Avatar
If you had a temp correction at the time you first tried the ignition cut it could well have been cutting with a richer mixture causing flames.
Both fuel and ignition cut works just fine.
alphawolff
Nov 17, 2015 05:57 PM
Captain_Panic
Alternative Fuels
Sep 16, 2015 02:06 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
