Sponsored by: CARiD
tuning tips for high compression turbo
Old Feb 18, 2008 | 01:37 AM
drift monster's Avatar
can someone give me a baseline for timing and afr?
right now i just put it in exactly at tdc and locked it down
i tuned afr to around 11.0 to 1 on 91 octane
s4 street ported turbo motor with s5 NA rotors (9.7?) and counterweight
A/R .60 M24 B.O. Garrett hybrid 28mm wastegate boosting 10 lbs
V mounted, 3 inch DP and exhaust
safc 1 , rtek 1.8 (retards timing 1 degree every pound boosted over 9/built in fcd etc.) with 720 injectors all around
aeromotive fpr with ss fuel lines parrallel, walbro 255
plx r 500 wideband/egt/knock controller
im also getting this lean spot at light throttle at 3500.
thanks in advanced
Old Feb 18, 2008 | 04:30 AM
Hellbent1stN2ndownr's Avatar
lean spot at 3500? could be a grounding issue.
Old Feb 18, 2008 | 09:32 PM
yea im gonna REcheck all the grounds. any other tips??!?!?!?!?!
Old Feb 18, 2008 | 11:03 PM
mzrx7man's Avatar
sideways!!
ive owned a 2.0 and did alot of research on the other rtek's. the rtek 1.X's dont retard timing enough. i would recommend manually retarding timing an additional degree per psi after 9 lbs.
as for the lean spot, like stated above, a grounding issue would be a good place to start. have u gotten the secondary stumble fix yet? if so, i would just get alittle more aggressive with the fuel to smooth out the injector transition.
Old Feb 19, 2008 | 11:35 PM
i made another post in the rotary performance thread and philiptompkins said to advance it more
Old Feb 19, 2008 | 11:51 PM
mzrx7man's Avatar
sideways!!
advance (more power) = more of a chance to blow ur **** up
retard (lose alittle power) = way safer
check the other thread...
immanuel__7
89
Sep 5, 2015 10:23 AM
elfking
Aug 19, 2015 09:48 PM
Wolf_
Aug 11, 2015 04:23 PM
