13b missing
Old Feb 17, 2008 | 07:48 AM
Zemzee8's Avatar
Newbie
TX 13b missing
My 2 lower plugs not fireing, some oil on plug's not wet just kinda burnt, no nothing about 13b, any suggestions please..
Old Feb 17, 2008 | 02:35 PM
ultimatejay's Avatar
Need more info, like what year car, mileage on the engine, was it running before or in storage, etc? First thing to check is spark. Pull a good spark plug and put it in one of the leading plug wires. Rest it somewhere away from the engine where you can crank the engine over and see if you are getting spark. If you are not, check your cap and rotor- this is why I need to know what year car you have etc-. Most times if you are getting spark on the trailing- top plugs, and none on the leading- bottom plugs, or vise versa, then you probably have a bad ignitor. If you have spark then I would do a compression test or try a new set of plugs. Your plugs just may be fouled.
Old Feb 19, 2008 | 03:11 PM
Zemzee8's Avatar
Newbie
13b missing
Ultimatejay, its a rebuilt 88 less then 1800 miles on it, it was running fine then its started missing, the 2 top plugs are clean, the bottom are not, looks like ioil is int the chamber, but its not wet on pluges..Will try what u said first..Thanks..Alex.Tx
Lou Byer
20
Oct 12, 2020 08:03 PM
invinciblejets
Sep 13, 2015 08:22 AM
chiefmg
Sep 10, 2015 07:46 AM
