Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Xtreme EFI from EFI SYSTEMS
Old Apr 20, 2002 | 11:53 PM
Does anybody have any thoughts or experience about the new pms from Efisystems, inc.
They say that it can manage a 20B engine
Bruno
Old Apr 21, 2002 | 12:04 AM
kabooski's Avatar
Laying Down Rotary Law
release: june 2002
Overview
The new Xtreme EFI is designed to be one of the most user friendly systems on the market today. The Xtreme EFI features a unique connection system that works like an adapter. This will allow the user to plug into their OEM harness without the need of a wiring harness. It is shipped with 12 sequential injector peak & hold drivers. The ignition can control up to 8 individual coils or 16 as waste spark. Our over 20 years of experience working with street and racing EFI has enabled us to offer the advanced features of the Xtreme EFI as standard equipment at a reasonable price. Each Xtreme EFI will be pre programmed with a basic program so the car will start and run. Tables
- Fuel/Ignition
- TPS 32x64 F/I
- Map 32 x 64 F/I
- Mass 32 x 64 F/I
- Water Temp x Rpm 8 x 8 F
- Water Temp x Load 8 x 8 F
- Air Temp x Load 8 x 8 F/I
- Accel x Prm 8 x 1 F/I
- Decel Rpm shut off
- Idle Fuel
- Wot fuel & timing
- Start fuel & timing
- Sequential Inj timing x # of Inj.
- Sequential Inj trim x # of Inj.
- Secondary injectors can be phased in based on the primary duty cycle as a percent or as a separate map
- Air/fuel trim based on narrow bandor wide band oxygen sensor (temperature compensated)
Hardware
- 40 mhz 32 bit Intel microprocessor
- 12 Switch mode P/H injector drivers
- 8 Ignition module drivers or 16 waste spark
- 512k Flash
- 256k EEprom
- 1 meg Ram
- 4 Frequency inputs
- 12 A/D inputs 0-5v 10 bit
- 2 dedicated differential O2 channels
- 1 Internal temperature sensor
- 1 12v battery monitor
- 8 PMW outputs
- 16 Aux output ports
- 16 Digital inputs
- 1 CAN port (option)
- 1 RS232 port
- 1 USB (option)
- Fully EMI hardened Aluminum Enclosure 6x7 Options
- Boost control x Rpm or Mph
- Idle speed control
- Nitrous control
- Rev limiter
- Speed Limiter
- 16 Aux port outputs (setup via software)
- 16 Aux port inputs (setup via software)
- Load input as either voltage or freq
- Tach out
- 1-12 cyl, 2 or 3 Rotary ignition
- Mag/Hall crank pickup can be configured via software (32-2, 36 2, 60-2) + standard pickups
- All sensors and index’s can be configured via software up to 16000 rpm
Old Apr 21, 2002 | 12:14 AM
i JUST SAY WOW
hOW COME ALL OF THIS INFORMATION IS NOT ABVAILABLE ON THE INTERNET YET.
hEY AND IS AMERICAN!
WHO CAN i CONTACT THERE?
dO YOU WORK THERE, OWN THE PLACE, HOW COME YOU SAY WE, WHATS YOUR JOB THERE.?
i WILL NEED A QUOTE FOR A 20b PERIPHERICAL ENGINE.
bRUNO
Old Apr 21, 2002 | 12:05 PM
Evil Aviator's Avatar
Rotorhead
bRUNO
Um, this IS the internet.
http://www.andersonfordmotorsport.com
It looks like one of EFI Sys's products (AKA the PFS PMS):
http://www.efisystems.com/
Old Apr 21, 2002 | 12:09 PM
LUV94RX7's Avatar
Oldie, but Goodie
New Xtreme EFI from EFI Systems
See page 73 of the latest June Turbo Magazine. Lots of advanced features. List is $1175 and it's coming soon.
Ken
Old May 9, 2003 | 09:58 AM
rxrotary2_7's Avatar
it is?
the internet is still around?
lol
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
jim_chung
1st Gen General Discussion
Oct 4, 2015 09:09 AM
Zinraf
Oct 1, 2015 01:09 PM
RuffRx7
Oct 1, 2015 03:08 AM
Turblown
Sep 30, 2015 05:58 PM
