Would i be ok if...
Old Feb 9, 2008 | 08:46 PM
silverTRD's Avatar
Time or Money, Pick one
Would i be ok if...
i had a thread here a while back and the answer to the question was to run the kit since i have it....
but i just want to make sure that i will be ok because i am setting up my car for roadracing and hopefully i can get it done in time for mazdafest at buttonwillow, in the heat of summer. so i want to use for cooling as well
so i would appreciate opinions on if i would be safe with my kit for roadcoarsing.
heres the details
http://www.aquamist.co.uk/cp/806-009/806-009.html
TIA
michael
Old Feb 10, 2008 | 10:29 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
michael,
approx how much rwhp will you be running on the roadcourse? what is your turbo setup?
what injectant do you plan to run? water, alcohol? or a mix?
do you have the injector duty cycle "summer?"
what size solenoid (deliverability) do you have?
howard
Old Feb 10, 2008 | 01:58 PM
silverTRD's Avatar
i'm on stock twins with stock ports. not sure on the power, i havent tuned yet because i'm not sure if i am going to use the AI or not.
i am going to be running 850/1300's for injectors and will be installing a new fuel pump shortly wired direct to the battery.
i was planning on using cold weather washer fluid, good idea?
i'm not sure on the solenoid, i have what came with the kit from aquamist.
Old Feb 11, 2008 | 07:27 AM
i consider your system to be well engineered. whether it is "o k" or not depends on the size of the solenoid and how your car is eventually tuned. since you will be primarily using AI to cool your motor the chances are what you have delivery-wise will be fine. yes, you can use windshield washer as injectant. if i were you i wouldn't as it has a tad of soap in it. i suggest distilled water given you wish to just cool your motor.
hc
Old Feb 11, 2008 | 08:06 PM
silverTRD's Avatar
i would'nt mind a bit more power of course but that is not the primary reason i want to run it. never thought about the soap in the washer fluid.
SpAm@FC
Dec 22, 2010 03:43 AM
TwinTurbo'D
14
Jun 26, 2004 06:09 AM
