My Rebirth of my Rx-7 to a Carb'ed 6 Port
Old Feb 5, 2008 | 05:50 PM
ImprezedRS's Avatar
Damnit, steel doors hurt!
Some of you all might remember my old thread of turboing the 6 port and then redoing it with much bigger turbo and then the downfall of it well now i redoing it all but carbed heres some pics of it so far.
Attached Thumbnails My Rebirth of my Rx-7 to a Carb'ed 6 Port-untitled-3.jpg   My Rebirth of my Rx-7 to a Carb'ed 6 Port-untitled-4.jpg
Old Feb 6, 2008 | 12:43 AM
Hypertek's Avatar
Slowpoke
what are you benefiting from this?
Old Feb 6, 2008 | 01:41 AM
ImprezedRS's Avatar
well for one a car to drive once i sell my Z4 and Jeep and get my Ducati Monster
Old Feb 9, 2008 | 12:34 AM
ImprezedRS's Avatar
should be running tomorow
Old Feb 9, 2008 | 01:42 AM
rx7ryder's Avatar
CenFlaRxClub
that's how I have my 7. its n/a carb'ed 6 port. I have a holley 600 on two barrels, racing beat from the header to the dual exhaust, bronze clutch, e-fan, some other goodies. but yea its nice to see I'm not the only one.
Old Feb 9, 2008 | 07:18 PM
ImprezedRS's Avatar
started it up today still need to finish wiring it
Old Mar 9, 2008 | 08:40 PM
ImprezedRS's Avatar
will be finishing it tues and weds will have new pics up of it, after I get it running right I going to have the new paint job done on it
Old Mar 9, 2008 | 10:54 PM
Bama420's Avatar
Upside-umop Racing
But why are you carbing a previously fuel injected car? That's retarded in my opinion. You're losing the little bit of fuel economy that we rotary owners have and you can't be gaining much if any power.
Old Mar 10, 2008 | 01:30 PM
ImprezedRS's Avatar
search my name and read my old thread
Old Apr 9, 2008 | 09:22 PM
ImprezedRS's Avatar
an updated picture
Old Apr 9, 2008 | 09:56 PM
Mike0071's Avatar
Cause he felt like it; I'm sure it makes his whole setup a whole lot lighter...
Old Apr 9, 2008 | 11:14 PM
Hypertek's Avatar
Slowpoke
it may be lighter, but ehh.. i guess your plans are to eventually turbo it, in which you wont need expensive computers etc. just tuning the carbs? seems difficult to me. esp when a stock tII would have more hp...
but its cool, esp the empty looking engine bay
Old Apr 10, 2008 | 10:31 AM
KNONFS's Avatar
B O R I C U A
Wrong, OEM EFI vs his carb setup; the carb setup will yield more HP.
Old Apr 10, 2008 | 11:56 AM
RETed's Avatar
WRONG.
EFI or carb doesn't matter of horsepower potential.
The engine still will only take X amount of air, and you still need to dial in Y amount of fuel.
There's no rocket science behind it.
If you're going to argue for carbs, do it right.
The shorter, more compact INTAKE MANIFOLD will yield more top end power over the stock EFI intake manifold.
...sure.
Throw on an ITB with fuel injectors, and your carb set-up will not make more power.
If anything, low end power suffers.
Mileage suffers.
Personally, carb conversions are for people who can't figure out the stock EFI...
You make the call on about their intelligence.
Side note, I think I called it that the OP was never going to finish that project in the first place...
-Ted
Old Apr 10, 2008 | 12:43 PM
KNONFS's Avatar
B O R I C U A
...sure.
You know that's what I meant, specially since there is no carb intake manifold, that will yield less top end than the OEM efi (unless you adapt an old OEM 12A\13B intake manifold to the 2ndg gen)
You missed the part were I said OEM EFI vs his carb setup
Chit, a stand alone on a OEM intake manifold might yield the same peak HP as an aftermarket carb setup.
Whoa, what is there to figure out on the stock EFI? If you want the most HP out of a EFI NA setup, there won't be any STOCK EFI component on the car.
Old Apr 10, 2008 | 06:31 PM
ImprezedRS's Avatar
done did the turbo efI now I want carb nothing about not knowing Efi at all
Old Apr 11, 2008 | 04:56 PM
Hypertek's Avatar
Slowpoke
ok how much hp can you get from this?
i want to find a 70s porches 911 and put a rotary in it because Porsche motors are expensive.. really expensive..
and a carbed 13b would probably be easier to setup/get the ball rolling instead of playing with all the EFI equipment.
Old Apr 12, 2008 | 07:57 PM
ImprezedRS's Avatar
with this setup and maybe doing a street port i'm looking about 220 rwhp
Old Apr 12, 2008 | 07:59 PM
ImprezedRS's Avatar
Also with the racing beat holley kit, it fired right up and idled no problems, it pretty much comes setup to run and they have it tuned for stock motor with the race pipes from what they told me.
Old Apr 12, 2008 | 08:24 PM
ImprezedRS's Avatar
pics of my old setups
Attached Thumbnails My Rebirth of my Rx-7 to a Carb'ed 6 Port-image000.jpg   My Rebirth of my Rx-7 to a Carb'ed 6 Port-image035.jpg   My Rebirth of my Rx-7 to a Carb'ed 6 Port-image036.jpg   My Rebirth of my Rx-7 to a Carb'ed 6 Port-image041.jpg
Old Apr 12, 2008 | 08:25 PM
ImprezedRS's Avatar
More pictures, and yes thats a S5 NA 6 port block not a TII block
Attached Thumbnails My Rebirth of my Rx-7 to a Carb'ed 6 Port-image2.jpg   My Rebirth of my Rx-7 to a Carb'ed 6 Port-image3.jpg   My Rebirth of my Rx-7 to a Carb'ed 6 Port-image6.jpg
Old Apr 12, 2008 | 10:50 PM
Juiceh's Avatar
Saiga-12 Power!
After driving an NA rotary, doing a turbo swap, then going big single turbo I can't for the life of me figure out why anyone would ever want to go from turbo to carb...
Good luck though, I hope you hit your goals. If you get what you want out of it and it makes you happy, thats all that matters in the end.
Old Apr 15, 2008 | 05:31 PM
daten's Avatar
what are you using for the ignition setup?
Old Apr 15, 2008 | 07:32 PM
ImprezedRS's Avatar
fb dizzy and msd blaster coils
Old Apr 15, 2008 | 08:58 PM
hatemy7's Avatar
Rotary
hey **** all those hater bro, your doing what you want to do . I think that is a real kewl swap in my opinion, Gl i hope you get what you want
