Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D TPS Problems
Old Jan 31, 2008 | 01:29 AM
raddavey's Avatar
TPS Problems
Ok i purchased the TPS from wolf but i'm having similar problems that i experienced with the old TPS. I set it up with the min/max feature using the handcontroller, but the resolution is just too small. What i mean is the 0% throttle is 4.4volts and the 106% is 4.49. So it works fine with no throttle and with full throttle but inbetween its just not accurate at all.
Any ideas?? The other TPS was like this as well. I checked with some base wolf base maps for other cars and most TPS's are setup with a min/max voltage of 1 - 4volts. Oh and its not the ecu because i'm borrowing a mates v400 while mine gets upgraded and its doing the same thing on both. There just doesn't seem to be enough resistance to drop the voltage.
I will check the output signal with a multimeter and see what it reads. Maybe i have it wired incorrectly.
Old Jan 31, 2008 | 06:17 AM
Michael Smith's Avatar
Talking
You are missing the earth to the TPS One end is +5 volts and the other is ground you have a missing ground!!!
Cheers
Michael Smith
Old Jan 31, 2008 | 06:41 AM
raddavey's Avatar
ok i'll check the ground wire maybe it's cut somewhere.
Thanks
Old Feb 2, 2008 | 01:52 AM
raddavey's Avatar
Ah i can't believe it. I had the ground and the signal wires wrong
Working perfect now. My old one would work fine too if i had it wired correct. I just wasted $70 ah well.
Old Feb 2, 2008 | 07:07 AM
Talking
Your Welcome, I have learn from experience just like you have.
Cheers
Michael Smith
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
