what auto X class am i
Old Jan 30, 2008 | 09:47 PM
aFBatw!'s Avatar
Noobist
im moving out of novice this year in auto x and was wondering if anyone can tell me what class i will be in. 85 gsl, i have an exaust and suspention mods (if i need to elaborate and be more specific on mods i will)
Old Jan 30, 2008 | 09:48 PM
aFBatw!'s Avatar
Noobist
oh yea and racing tires.
Old Jan 30, 2008 | 10:44 PM
Kentetsu's Avatar
Sounds like you're probably going into CSP.
Old Jan 30, 2008 | 10:54 PM
Chiketkd's Avatar
B-Stock autocrosser
What suspension mods do you have? It sounds like CSP to me as well.
Old Jan 31, 2008 | 12:57 AM
aFBatw!'s Avatar
Noobist
yeah csp is what i initialy thought but others have told me othrwise dont remember what it was. anyway i have st springs and swaybars tokico blues and uerethane bushings
Old Jan 31, 2008 | 01:52 AM
justint5387's Avatar
CPS Motorsport
You are in CSP since you have LSD, you can't run a clutch type LSD in STS2
Old Jan 31, 2008 | 08:08 AM
Chiketkd's Avatar
B-Stock autocrosser
True, and he also mentioned he runs race tires. I don't think he was considering STS2 as an option.
To the OP, do you run dot legal r-comps or full slicks?
Old Jan 31, 2008 | 02:25 PM
finky's Avatar
Well, if you have removed any interior at all other than radio and changing seats then that could put you into F Prepared. That could be a complaint by other competitors.
Old Jan 31, 2008 | 02:44 PM
Valkyrie's Avatar
If all you have is a cat back, springs/shocks, and DOT-approved race tires, you're AOK for stock class (might be E Stock, which is what NA FCs are in, but I'm not sure).
Any mod that people can't see isn't going to bother them (including an LSD)... but don't take that as an excuse to blatantly cheat.
I personally think most people aren't going to be offended if you've got a few mods that would bump you into a class that's WAY out of your league (in terms of total mods allowed, and budget required to be competitive)... as long as you're not beating them :p
Old Jan 31, 2008 | 02:47 PM
aFBatw!'s Avatar
Noobist
i have a full exaust and the tires are shaved proxes ra-1's cars not stripped all interior is stil intact
Old Jan 31, 2008 | 02:58 PM
Chiketkd's Avatar
B-Stock autocrosser
Incorrect. In stock classes you can't change springs. You can run aftermarket shocks (tokicos, konis, bilsteins, etc), but springs must be OE.
Definitely sounds like CSP.
Old Jan 31, 2008 | 03:07 PM
mazda6guy's Avatar
FB Maniac
If you do anything internally to the engine be ready to move to SM2. As it sounds with your mods you are definitely in CSP like me. Be ready to start battling with CRXs and Miatas.
Old Jan 31, 2008 | 03:36 PM
aFBatw!'s Avatar
Noobist
theres a guy in a 944 8 valve n/a that i was battling last year with identical times damn near every time that i think is my best competition, he'll probably be in the same class as me but the miatas were kickin my ***, i guess i gotta step it up this year
Old Jan 31, 2008 | 04:02 PM
Chiketkd's Avatar
B-Stock autocrosser
^Get some camber plates & big r-comp tires (275/35/15 A6's anyone) and you'll see a big drop in your time!
Old Jan 31, 2008 | 04:31 PM
aFBatw!'s Avatar
Noobist
275's isnt that a little big for my car. where can i get camber plates the ones at ground control seem kinda pricey.
Old Jan 31, 2008 | 06:05 PM
finky's Avatar
Break out the sawzall. Search SCCAforums.com for CSP and see what the Miata guys are doing. At least get 13X8s if you can afford and want to be competitve. I don't remember if your car came with the 13b or not but you can upgrade to all of the parts of a GSL-SE. CSP allows best of the breed mods as long as they are on the same designated line in the rule book. I am not a first gen guy but I have driven a car with the full Jim Susko 3 link??? (not sure exactly what it is called. If you search you will find it) and it was a very fast car. The owner did not know how fast it could be until I beat him by 3 sec. in it.
Old Jan 31, 2008 | 06:16 PM
Valkyrie's Avatar
Wrong. Be prepared to get SMEARED by Miatas and CRXs.
Old Jan 31, 2008 | 06:26 PM
mazda6guy's Avatar
FB Maniac
Actually swapping to a GSL-SE suspension adds a tad bit of weight to the car. I see no huge advantage in autox with this swap unless you are trying to change bolt patterns for a wider selection of rims. I would do the swap if I had rear drum brakes though. Also this is the link to the 3 link and panhard bar setup. http://www.gforceengineering.net/ My next mods will be this setup on my FB. Also I would invest in the Mazda 1st Gen Setup Manual /Shock Tuning Guide from Mr. Jim Susko.
Old Jan 31, 2008 | 07:28 PM
Chiketkd's Avatar
B-Stock autocrosser
No. In Street Prepared you need to run the biggest tires possible that still allow you to keep a good gearing advantage.
This is a pic of a CSP miata that competes here in VA. He's quick, and if he went to nationals would probably finish mid-pack or thereabouts. He has a light-weight NA miata with the 1.8L engine out of an NB - his car is probably in the 2,200-2,300lb range:
Btw, those are 275/35/15's on that car!
And I'll add this pic of Jason Uyeda's BSP S2000 - again another lightweight car (2,600lb range) - and he's one of the fastest in the class nationally.
He runs 18x11 custom CCW's front and rear, with 285/30/18 front and 295/30/18 rear.
Personally I'd keep your current mods, get a set of 15x10" wheels that work with your bolt pattern along with some 275/35/15 A6's and go out there and have fun! Your car is so light, one set should probably last you a full season.
Old Jan 31, 2008 | 09:43 PM
aFBatw!'s Avatar
Noobist
yeah tires are definately on the to-buy list im curently using 185/70r13s i have alot of tire roll which camberplates and a lower profile tire would get rid of
Old Jan 31, 2008 | 11:34 PM
mikeric's Avatar
FB=OS Giken LSD
SCCA Rule book
When in doubt, read the rule book. The e-version is free. Here is the link: http://www.scca.com/contentpage.aspx?content=44. They also have a email address on that page that you can write to to clarify any questions.
By the way, if you want to be competitive, I'm giving up (selling) my light '92 Miata with the 1.8 '00 engine. More info, PM me.
Old Feb 1, 2008 | 04:44 AM
Kentetsu's Avatar
Miatas aren't all that far out of reach, once you strap on the race rubber.
Camber plates, coil overs, adjustable rear spring perches, heavy front swaybar. Those are the best place to start (in my opinion) for better handling. Assuming of course that the rest of the car is in good or repaired condition (brakes, bushings, etc.)...
Check out www.re-speed.com for race parts. Billy is a forum member, and pays attention to what we want. Prices are good, customer support is phenominal.
Old Feb 1, 2008 | 10:19 AM
Chiketkd's Avatar
B-Stock autocrosser
+1 Very true. If he preps the car wisely, he should definitely be able to do well in the class.
aFBatw, how much autocross experience do you have? If not a lot, you might want to look into a few autocross schools (e.g. Evolution School). I have 2 years of experience and took an Evo School last Spring - it has done wonders for my driving.
Old Feb 1, 2008 | 09:14 PM
aFBatw!'s Avatar
Noobist
ive only been doing it for one season but i agree a class in anything is always a good idea theres always room for improvement. my car is a daily driver too so mods are limited at this point
Old Feb 2, 2008 | 10:53 AM
Valkyrie's Avatar
The primary advantage of a school is that you get many more runs.
At a normal event, you literally only drive for 5-6 minutes (less if you're fast).
Which is why if you don't do a school, or otherwise practice somehow, it takes many seasons to get truly competitive.
