need help with offset
Old Jan 29, 2008 | 02:31 PM
irishrx7's Avatar
ok first up i know this has probly been done to death so sorry but im trying to order a set of new rims for my fd. car had re amemiya rear arches and have a set of burnoutfront fenders on there way over, im ordering a set of 17 by 10 inch wide. 5zigen FN01R-C (bronze) gona run 265 40s on the back and 245 50s on the front.
what sort of ofset will i need to fill the arches right out? ill be rolling the original rear arch thats hidden by the RE-A arch.
any help at all guys is much apriacted.
here a few pics to help yas out.
what they will look like
Old Jan 29, 2008 | 04:09 PM
Risky Devil's Avatar
U.S.A
17x10 +12 , lowest offset size for FN01R-C.
Maybe a 10+/15+ mm spacer to be perfect flush
Why run 50 profile in the front?
Why aren't your fender arches cut for the over fenders?
Old Jan 30, 2008 | 09:18 AM
irishrx7's Avatar
typo with the 50s on the front. should have been 40s. the original fenders where never cut as the rims on it now didnt need anything cut for it to fit.
so with that off set they should be right out in the arch yea>?
Old Jan 30, 2008 | 02:45 PM
ARD T2's Avatar
My suggestion would be this:
1. Trim or roll the OEM Fender that sits inside the RE-A Arches. You're not really getting extra space from what I can tell.
What size wheel will you run up front? and are you getting Burnout fenders for the front or replacing both front and rear?
I personally don't think your fitment will work on the FD with those tire sizes.
FYI, we ship int'l via USPS no duties. So let me know if you're ordering stateside.
Thanks, Rishie
Old Jan 31, 2008 | 11:09 AM
irishrx7's Avatar
Thanks, Rishie
by the looks from the rear end im gona have about 3/4 inch extra over stock on the rear when the arches are cut/rolled. i want 10 by 17s all round for the concave look. the rear arches are staying re and new burnout front fenders are going on. what tyre size/offset do you recomened?
and pm sent about prices
Old Jan 31, 2008 | 02:07 PM
ARD T2's Avatar
OK so this is my recommendation for the best handling setup for what you're trying to do:
1. Run 255/40/17 all around so you have even ride height and symmetry
2. Based on what you're stating i estimate you can run:
17x10 +35 Front with 255/40/17 - IN STOCK ONLY 2 LEFT
17x10 +25 Rear with 255/40/17 - ABOUT 20PCS IN STOCK.
PLEASE GET BACK TO ME ASAP CAUSE THE +35'S ARE GONNA RUN OUT.
Rishie
Rishie
doritoloco
Sep 17, 2015 03:51 PM
