Ram Air
Old Apr 18, 2002 | 01:16 PM
crankit's Avatar
Ram Air
Cold air setups are nice and do the job of getting cooler air then is under the hood. I used a flexible gutter drain from home depot 2'x3' attached to the a/c then enlarged the hole to the left of the headlight motor rod, its already there just make bigger, put a collar in there and stuck the gutter hose from the carb there. Below that I used some dryer exhaust hose and matched it up between the vent in the front air dam and the hole I had cut. Airs colder the lower you get and it has a forced air effect.
Old Apr 18, 2002 | 01:23 PM
damon's Avatar
do you have any type of filter at the end or just suck all the debris into the a/c
I only ask because Im about to the same mod
Old Apr 18, 2002 | 02:01 PM
crankit's Avatar
k+n filter. After the a/c all hose
FlatVermin
22
Sep 27, 2015 05:42 AM
