Is a single Fuel pump good enough?
Plan on running 15-16 lbs at first, then plan on bumping it up to 28lbs of boost on the R85 turbo.
Streetport
Supra pump
Fuel surge cover
850/1600 inj
ssx FPR
I'm gonna add AI also.
Streetport
Supra pump
Fuel surge cover
850/1600 inj
ssx FPR
Negative, the supra pump will certainly not support 28 psi.
I run a single Apex'i BNR intank pump, it's proven sufficient for 19 psi on my 500R. I think Ernie T ran the apexi pump up to around 25 psi on a T-78.
There's a thread I started in the archives you might want to check out, 'fuel system ramblings.'
Correct me if I'm wrong, but a single supra pump can support up to about 500 horses? I'm pretty sure thats true, but then again im no guru
BTW, at 28 psi, your going to be above 500 rwhp, so my answer is a no.
-Nick
-Nick
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
