Sponsored by: CARiD
Cleaning used spark plugs
Old Jan 15, 2008 | 07:59 PM
Torque South's Avatar
Boost
I found this thread through searching:
https://www.rx7club.com/showthread.p...k+plug+cleaner
What's the best machine to get? Also, what's the best way to "bake" a plug?
After 1 cleaning, I will discard the plugs. I know blasting wears them down some, and you can't blast thin electrode plugs. Should still save me some $ since I like to swap plugs often. Thanks
Old Jan 15, 2008 | 09:04 PM
EricRyan's Avatar
Autocrossed. I got CONED!
Is there any known harm in brake parts cleaner and a wire frame brush?
Old Jan 15, 2008 | 09:51 PM
Mahjik's Avatar
Mr. Links
Blasting is fine, but as mentioned in the thread it won't revive the really dead plugs. If you do it regularly, you'd be surprised how long plugs can last on a rotary. I used the cheapy Harbor Freight one.
Old Jan 15, 2008 | 10:04 PM
2Lucky2tha7's Avatar
Back at it again!!
wire wheel and brake parts cleaner. Been doing that for 14 years now. Always worked and always will.
Old Jan 18, 2008 | 09:07 PM
Boost
Thanks for the responses. I bought the Harbor Freight one.
Old Jan 21, 2008 | 09:21 PM
Davidov's Avatar
I actually never had luck cleaning plugs on my FC. I did it a couple of times and I think the gas mileage got worse.
Old Jan 21, 2008 | 11:16 PM
danny hahn's Avatar
I've thought about putting or making a cap to go over the electrode to protect it from the sand blasting.
Old Feb 8, 2008 | 06:17 PM
88rexvert's Avatar
doesnt obey speed limits
i know this post is kind of old but i use brake parts cleaner and a wire brush and not just in my 13b ive also used that method in my grand am and my corsica when i had it... just my 2 cents
Old Feb 8, 2008 | 06:47 PM
Boost
Cool. My dilemma is, the stock NGK 9 trailing plus (for a TurboII) that I use in my FD are cheap enough to just replace every time, but the expensive thin electrode (NGK 11.5) look like they aren't safe to sandblast...
Old Feb 8, 2008 | 07:26 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
soak the tips in BBQ cleaner for an hour then it's brake cleaner and toothbrush time.
Old Feb 8, 2008 | 07:47 PM
Boost
For the thin electrode race plugs? That sounds doable.
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
Joe428
16
Aug 19, 2015 06:24 PM
