Need Help with the Rear Wiper Setup
Old Jan 11, 2008 | 08:10 PM
Gyan's Avatar
I've never had this car operational yet. I bought it as a roller / project car so now I'm working on the systems. OK So I have the wiper arm installed on the hatch, it's wired up. As I understand it the timing of the wiper is controlled by CPU 1 & that's as much as I know. The highlights manual shows a picture of a front wiper switch & a rear wiper switch & they're the same looking ?? Is there a different switch with the rear wiper setup? How does it look / function differently? There is no rear washer bottle and the car came with a round plug plastic cap that covers the bottle hole.Any enlightenment on this subject would be much appreciated...thanks
Old Jan 11, 2008 | 08:22 PM
Busted7's Avatar
Will work for horsepower
I removed mine but the control is on the right handle behind the steering wheel and coms on by twisting. the fuss controls wiper and a/c and heat controls. If the heat controls work that tells you the power is there. I belive there is a cpu control but know nothing about it. Thats all i know. Good luck.
Old Jan 11, 2008 | 09:58 PM
FD3S-K's Avatar
Geby
Ill go get you pics right now, since your a bc dude!
Old Jan 11, 2008 | 10:18 PM
FD3S-K's Avatar
Geby
Old Jan 11, 2008 | 10:31 PM
FD3S-K's Avatar
Geby
Rear end:
Old Jan 11, 2008 | 10:53 PM
Gyan's Avatar
Great pics thanks. That clears up the switch issue. My switch has a smooth outer end without the square window picture. That must be the rear hatch symbol & switch. So I guess I have to find a switch & go from there to wire it up. Has anyone upgraded from no rear wiper to having one? Is the harness already there? Please say YES!!
