Single turbo suggestions....
Old Dec 14, 2007 | 01:36 PM
duwacker69's Avatar
-----MYOLD7UPYOURS-------
I have ben debating for the past coupl of weeks on as to go with me 13B-RE stock twin turbo setup in my fc,or to swap in a larger single turbo setup, and I decide on the single turbo setup becaus of the money part of the after market ecu and tuning time..When I was at the junk yard the other day I came across a 91 Toyota Supra Turbo in great shape and the motor intact..It has the 1JZ-GTE engine and a VVT-i CT20 stock turbo and I want to know if this turbo will be sufficient enough for my 13b-re engine? And I would like to know about how much horsepower I would have with a N333 ecu,along with a 75mm fmic to control the engine?
Here are some of the specs on the turbocharger to save some of you time in helping me......Toyota CT20 (1JZ-GTE VVT-i Single Turbo)
The late-model Toyota 1JZ-GTE engine is very different to the earlier versions that most people recognise. While the early 1JZ uses a pair of compact turbochargers, the later version employs VVT-i technology and a large-capacity CT20 single turbo.
This is one of the sweetest Japanese import turbochargers you’ll stumble across.
The 1JZ-GTE is rated at the Japanese-regulation 206kW output and, looking at the physical size of the compressor and turbine, we guess this turbocharger can crank a massive 250kW without problems. The only limitation is the strength of its ceramic turbine wheel. As far as we can determine, this turbocharger uses a conventional-style centre bearing with water cooling.
The compressor inlet to this turbo measures 57mm diameter and the discharge nozzle (which uses a 2 bolt flange) is 45mm. The turbine passage is 48mm diameter and the mounting flange is 74 x 98mm. Four bolts connect the exhaust manifold to the turbine and five bolts are necessary for the dump pipe.
The 1JZ-GTE VVT-i CT20 is a fantastic, late-model turbocharger for big power applications.
I know its alot to read but i want to get my car on the road soon,i started to swap and body work lats rear november and i never even drove the car befor or any fc........Thanks for all the help guys...................Josh
Old Dec 15, 2007 | 10:51 PM
duwacker69's Avatar
C'mon people i need some help with this turbo choice...Its a decent size turbo and to me it seems like a good one to go with???Any help would be great........Thanx
Old Dec 15, 2007 | 11:18 PM
charlies7's Avatar
3rd rotors a charm
Going to be hard to get any feedback. I doubt that anyone has used this turbo.
Old Dec 15, 2007 | 11:45 PM
duwacker69's Avatar
Well the compressor housing is between 47mm-49mm,does this sound about right for a 13b-re????Ive done alot of checking on that turbo,and all i can find for sizes is that...Thanx
Old Dec 16, 2007 | 04:53 PM
duwacker69's Avatar
Turn out its not the ct20,its the ct26 and here are the exact specs on it.....Released in the late ‘80s, the CT26 turbo is recent enough to use a water-cooled centre core – a factor that contributes to its renowned reliability. The Supra’s compressor inlet is a gigantic 72mm diameter and the compressor discharge nozzle is 57mm. Both use a slip-on hose fitting. On the exhaust side, gasses pass through a 60mm diameter turbine passage and the mounting flange is 106 x 87mm. If that helps any,,,,,Thanxs
Old Dec 16, 2007 | 05:56 PM
diabolical1's Avatar
the turbo is too small for a rotary. look for something else.
also ... you need to do more research on your Toyota facts. there is a lot of misinformation in your original post.
Old Dec 16, 2007 | 10:23 PM
duwacker69's Avatar
Thanks,i tried to look up that info myself but i am not to intrested in toyota's so i lose interest pretty fast..lol..I guess ill keep looking.....
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
