Microtech timing question
Old Dec 10, 2007 | 01:12 PM
rx7legend's Avatar
Fc3s 4 life
timing question
hi, ive been finishing my project and im on the last phase of it, mounting the microtech lt-8 and the turbo. anyways i want to know what timing people are running here, ive been told to run at 10 degrees at most with pump gas, my tuner says whe can run 13-14 degrees without problems on stock pump, to tell you the truth im not very confident running 14 degrees on pump gas. car is a 1990 TII.
mods: koyo rad,turbosmart bov, turbosmart boost controller, rb turbo back, 800cc secondaries, spalm e-fan, turbonetics deltagate external wastegate, t3/t4 turbo to4b 50 trim, microtech lt-8, walbro 255fp, aeromotive fpr, running premix.
i think that's the important thinks. well let me know.
thanks
Old Dec 10, 2007 | 06:06 PM
rx72c's Avatar
Top Answer: 1
I cant see anywere were you have mentioned boost?
what fuel do you guys have at the pump?
91, 95 or 98 octane?
Old Dec 10, 2007 | 09:28 PM
rx7legend's Avatar
Fc3s 4 life
well most places have 91 but there are a couple with 93
Old Dec 11, 2007 | 12:41 AM
rx72c's Avatar
Top Answer: 1
what boost?
Old Dec 11, 2007 | 02:59 PM
rx7legend's Avatar
Fc3s 4 life
if your asking about psi im gonna run 14psi max.
Old Dec 11, 2007 | 05:04 PM
rx72c's Avatar
Top Answer: 1
So 91 octane. 14psi. Id run a 10.9:1 afr mixture, and run 12 degrees of timing. It will be reliable with these settings.
Old Dec 12, 2007 | 09:29 PM
rx7legend's Avatar
Fc3s 4 life
thank you for the response, ill guess ill try 10-12 degrees at first, im gonna street tune it for now. hoping for good numbers with these setup at least 300whp or so.
thanks
smikels
Rtek Forum
May 12, 2016 12:34 AM
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
