Bad wheel bearing?
Bad wheel bearing?
I think I have a bad wheel bearing. The noise sounds like wheel is rubbing on something, but it's not. The weird thing is, sometimes the noise is there and sometimes it's not. For example, I would drive and for 20 seconds the noise is there and then it goes away, but then 2 minutes later it comes back. If I have a bad wheel bearing, would the noise be there 24-7? It's been like this for 3 months but I can't seem to track where the noise is coming from. I tried to make a video of the noise, but my exhaust system is too loud. Any thoughts?
jack up the corner
spin the wheel by hand and feel for any roughness in the rotation.
grab the wheel at the 12 and 6 oclock positions and check for axial play. it should be 100% solid.
if that all checks out the wheel bearing is probably fine
