for rotor heads only
Old Apr 13, 2002 | 11:58 AM
prmazdarx7's Avatar
ok i have seen this done but need a bit more info on what all it takes to do it
i am planing on installing a mazda b2000 pick up truck tansmision on my rx7 i know it will have more low end and i would have to give up my high.
but i need detail on how to install it and what mods i would have to do to the car to make the trany fit?
your next door rotorhead
Old Apr 13, 2002 | 01:04 PM
KNONFS's Avatar
B O R I C U A
what's up Boricua? I believe Ted knows the answer, If my memory serves me correct, those trans are the same as in the T2. I know I saw a post once, but can't remember exactly what was the difference between them (if any)!
Old Apr 13, 2002 | 01:49 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
If it is a T2 Tranny caseing.....
... then it should just bolt up. All you'll need otherwise is 2nd Gen Auto driveshaft.
Only question is whether you'll need to go to a T2 clutch. If you do, then you'll need to change the flywheel because of the larger circumference (sp?). If so, then when you grab the Auto driveshaft, be sure and grab the counter weight between the auto tranny torque converter and engine block as it will be easier to also go lightened steel (my choice) or aluminum aftermarket.
Have fun.
Old Apr 13, 2002 | 02:14 PM
from what judgeito told me, he had to swap out the trans bell housing to make a TII engine fit the b2000 pick trans.
He had a B2000 with a TII engine. He sold his truck now, but i saw it a few days ago and it does 12s in the 1/4 mile. Fast truck.
C
Old Apr 13, 2002 | 04:01 PM
Aaron Cake's Avatar
Engine, Not Motor
Re: If it is a T2 Tranny caseing.....
WRONG. The 2nd gen auto driveshaft will NOT allow a TII transmission to bolt to an NA diff. You either need a custom shaft fabbed (NA yolk, TII flange) or you need to install the TII rear subframe and all related components.
ZacMan
Sep 19, 2015 09:20 PM
Ian_D
Sep 6, 2015 10:38 PM
