Perplexing Problem
Old Nov 24, 2007 | 09:34 AM
rotaryspitfire's Avatar
Rotor Head
Perplexing Problem
I have a 90 Turbo II that has rough/no idle and hesitation at approx 1300-2000 RPM. Other wise the car runs strong. Here is what I have done.
First, no emissions.........
TPS checks, replaced with another good TPS and no change in problem
All sensors check, double/triple checked them with a Fluke 88AN Multimeter.
All connectors cleaned
Continuity between sensors and main harness plugs are good
Throttle body removed and all settings adjusted and reset to factory specs
If I retard the timing as far as adjustment allows, the problem gets better. During a rebuild, can the person somehow put back components 180 off? I know the pulley with the timing marks on it only fit one way.
The crank angle sensors is within specs
I wonder if someone removed the gear on the sensor and replaced it backwards.
Any thoughts?
Old Nov 24, 2007 | 10:18 AM
Turblown's Avatar
Turn up the boost
Can't happen. If the timing light is used correctly and shows the timing marks near the indicator on the front cover. Then thats where you're timing is, and not 180 off. Retarded timing at idle always makes for a smoother runner engine.
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
