Sponsored by: CARiD
13b 6prt weber carb hard cold start
Old Nov 23, 2007 | 09:13 PM
rx7 vinnie's Avatar
tap, nap, snap....pick 1
ok i finally broke down and gonna ask for help . i have a 86 rx7 i have had for about 12 years was bone stock till bout 8 years ago. now its a full csp solo track prepped racecar i have been racing ever since. i rebuilt the motor bout 4 years ago with atkins internals its got a weber 48 dcoe 2brl carb and a mild street port. my question is my car is so hard to get running when its cold but when its warmed up it starts right up by just bumping the starter its been that way ever since i got rid of the e.f.i. need some suggestions, tired of burning up starters every 3 months during the race season. sorry for the long post.......thanks in advance
Old Nov 24, 2007 | 02:34 AM
diabolical1's Avatar
Nashville winters ... perhaps it's simply contraction because of temps. maybe try some oil in the throttles or a coolant heater?
Old Nov 24, 2007 | 11:10 AM
rx7 vinnie's Avatar
this also happens in the summer time heat too. To get her started a have to choke the carb,crank the hell out of it, and basically flood it to get her to start. the carb doesnt have a choke but i made a cap to simulate a choke. It just frustrates me sometime thats i have to go thru this all the time to be compete but theres no gaurantee it will start. I may just get rid of the carb and go with and I.T.B. but thats lots more money. suggestions please
Old Nov 24, 2007 | 04:23 PM
a true choke does make life easier. i used my Dell'Orto on my 6-port for years and never had starting issues - in any weather. i drove through many New York winters and then moved to ****-hot Florida. in the summertime i could start the car without the choke and though it would idle really low until it got warm, it wouldn't die out.
anyway, the choice is yours. maybe you could try getting one with a choke first. it shouldn't be much money-wise by the time you sell yours.
on a side note, what idle jets are you running?
Old Nov 24, 2007 | 04:47 PM
89fc3sT2's Avatar
Raushan
I have the same 48 I pump the gas about 4 times then start it hold the gas a little about 1500 to get it warmed up then after a while it run by its self.
Old Nov 25, 2007 | 08:37 PM
rx7 vinnie's Avatar
diabolical, i thought about either running a dellorto but i heard parts are hard to find but i may go with a 45dcoe its has a mechanical choke. I dont wanna get rid of this setup bc its was a gift. I have no idea what jets i have #'s scratched off.
89fc, what kind of jets are you running? this setup i have has always been a nightmare. I think its the tune nobody fools with carbs on rotaries here just
turbocharged monsters
Old Nov 26, 2007 | 04:27 PM
you probably have a 48 DCO then, because i think the "E" in DCOE means that the carb has a choke. anyway, keep the 48, it makes no sense downgrading to a 45 if you have a 48. if i read correctly, then you got this thing as a gift? what kind of car did it come off of last. it's possible your setup (jetting, venturis, etc.) could be all wrong. you're right about parts for the Dell'Orto - at least rebuild parts. jets are still fairly easy to find. however, it is for that reason why if i ever go catb again, i'd go with a true Weber! so i'd advise you to stick with it.
perhaps all you need is to pull the thing apart and rebuild it with known parts. i'm not a HUGE fan of that wraparound-style manifold, but it can perform very well - especially for a street-driven car.
Old Nov 27, 2007 | 10:08 AM
rx7 vinnie's Avatar
it came off a imsa class gsl-se it just maybe jetted wrong for my motor but from what i heard it did good on the first gen. if you know a good source besides twm inductions (they didn't answer my emails....guess they dont want my money)for a dcoE let me know. heres the pics of my setup. also have a 87t2 next to it that has a 13b-re single turbo setup im workin on thats breakin' me
Attached Thumbnails 13b 6prt weber carb hard cold start-car-pics-001.jpg   13b 6prt weber carb hard cold start-car-pics-002.jpg   13b 6prt weber carb hard cold start-car-pics-064.jpg
Old Nov 28, 2007 | 06:08 AM
why don't you check the board's classifieds first before sourcing a new one?
Old Nov 28, 2007 | 09:20 AM
rx7 vinnie's Avatar
i sure do appreciate your help.
Old Nov 28, 2007 | 09:51 AM
Tom93R1's Avatar
gross polluter
My REPU has the same setup, a stock 6-port motor with a Weber 48 DCO carb. Now that the motor is getting very low compression its a pain in the *** to start, it runs good but backfires alot now as well. When the motor was still tight it would fire up every time if I pumped it about 10 times then cranked. Winter time in Colorado I might have to do this twice but still rarely a problem. On the very coldest of mornings I would take a plastic grocery bag and wrap it around the filter as a choke, but that was quite rare.
What is your method for starting?
Old Nov 28, 2007 | 10:25 AM
rx7 vinnie's Avatar
i do the same thing you do when i have my k&n filter on it.
but when i have the velocity stack on it for autocrossing i use a radius arm bushings from a ford f150 and stick it in the stacks.
i checked compression on it its not that bad 90 front 110 rear. but even when i built it fresh it was still hard to start. and i burn up my starter doing it. what jets are you running?
Old Dec 6, 2007 | 09:38 AM
rx7 vinnie's Avatar
I need weber 48 dco jetting suggestions for the setup above please
Old Dec 10, 2007 | 10:46 PM
i think i have my old Dell settings somewhere. i'll see if i can find them post what i had in my idle circuit. i'm tempted to say i was running 70s. i honestly don't know how closely they translate to sizes with the Weber DCO, but if it at all helps any, then you're welcome to them.
Old Dec 11, 2007 | 07:50 AM
Tom93R1's Avatar
gross polluter
I dont remember the jets off the top of my head but I think the main jets are 200 with 180 air correctors. The idle jets I think were 45 or 50, but I would have to check. I am on a business trip so cannot verify until this weekend.
Old Dec 12, 2007 | 02:02 PM
rx7 vinnie's Avatar
ya'll been alot of help guys...... now my next question is where is a good place to
buy these assortment of jets? now its down time, i can fine tune it for the '08 season.
Old Dec 12, 2007 | 03:51 PM
Tom93R1's Avatar
gross polluter
I always get my lets from local vw beetle performance shop. they usually look at me funny because the jets are huge compared to what a vw uses.
Kyo
Apr 13, 2019 09:24 AM
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
