Emissions Removal and Solenoids (S5 NA)
Old Nov 21, 2007 | 02:10 PM
Gringo Grande's Avatar
1.5 Goodfella's Tall
I recently completed my first attempt at removing emissions on an S5. Yes I know...everyone point the finger at the n00b and
There seems to be a massive vacuum leak coming from the solenoid cluster...would this mean I most likely forgot to cap something? Capped something I shouldn't have? Or do I need to disconnect one of the solenoids? Possibly the brown (I believe) one?
Thanks!
GG
Old Nov 21, 2007 | 02:41 PM
89rxgtu's Avatar
is it worth taking the emissions off?
Old Nov 21, 2007 | 03:07 PM
On an S5 NA? Probably not but I've got 2 so I figured why not try it on one. Plus I like to tinker so I want to try and make an electronic 6port actuator, etc.
GG
Old Nov 21, 2007 | 03:35 PM
dirteeboy808's Avatar
go for it....
I just did mine, cleaned out the engine bay real nicely........tossed the AC compressor and PS pump....relieve the motor from some lag, too
Old Nov 21, 2007 | 04:52 PM
villin's Avatar
flat black fury
why keep the rack there anyway? just pull it of completely,run new fuel lines and vaccum lines and youll be fine. if your completely removing emissions theres no need for any of them.
Old Nov 21, 2007 | 05:40 PM
Villin - You need to come to Gainesville one day and help with this! =)
The first time I do something, I need photos and/or help...don't do good with just reading. After I do it once...money.
So you are saying I should pull the entire solenoid rack?
GG
Bauer778
Nov 4, 2015 04:42 PM
ZacMan
Sep 19, 2015 09:20 PM
