Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek How bad is it if i am getting knock timing retard?
Old Oct 31, 2007 | 06:51 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
i was logging a couple of 3rd gear runs, and in the last run i noticed my "timing retard" was up 7 degrees around 4krpm at 5psi. but the AFRs were around 11, so pretty rich. my staging is set to 3800 and you can see the AFR go up to 12.9 briefly, but that isnt terribly lean. log attached
what is the max the timing can be retarded due to the knock sensor?
Attached Thumbnails How bad is it if i am getting knock timing retard?-timingretard1.jpg
Old Feb 26, 2008 | 09:05 PM
gxl90rx7's Avatar
you know im still getting this problem. but only at 4krpm. at first i thought it was b/c of the secondaries running lean at staging, but i have lowered staging to 3krpm.
In my recent logs, you can see secondaries turn on at 3krpm, but the knock timing retard still goes up to 6 degrees right at 4krpm, no where near staging. afrs and timing both look the same as in the log above
i would post the logs, but i cant get any of the 2.1 logs to work with plviewer
Old Feb 26, 2008 | 09:12 PM
rogrx7's Avatar
Turbovert done.
what fuel pump ar u running?
Old Feb 26, 2008 | 09:37 PM
gxl90rx7's Avatar
walbro 255 with rewire, straight 12V. i have a fuel pressure gauge too, steady at around 40psi on part throttle
Old Feb 27, 2008 | 10:22 AM
rogrx7's Avatar
Turbovert done.
well there is a big change in the injector duty cycle... when the sec. injector kick in
I remember a previous thread about current pull being an issue..however your timing on your wide band seems to be fine.
Engine Management Forum
11
Nov 9, 2015 01:15 PM
Microtech
Aug 23, 2015 11:04 AM
20B Forum
Aug 19, 2015 01:47 PM
