Carbon fiber surrond!
I inquired about that...it wont fit w/o modification. IIRC, the steering column is not dead centered and/or the left/right isn't a perfect mirror image. Also, something about the curvature (in the vertical plane) of the piece in that one side curves more than the other but it's the opposite for North Am cars.
But I must admit, it's gorgeous. Now if someone can make it universal to fit not only the Stack but also Motec and/or PiResearch....schweet.
If you guys want one made out of carbon fiber, all I need is your gauge pod and I can cover it in Real cf. I could either cover it in its stock form or make it flat like that one and then cover it.
Check out http://www.carbonfiberparts.net I have a few pictures up of the stuff I have done. I am currently working on carbon fiber exterior door handles, and a cf version of the gauge pod that sits onto of the stock gauge pod and holds 2 gauges.
