Pictures of FC wheel fitment with specs... ***Picts-n-Specs ONLY***
Old Oct 21, 2007 | 10:26 PM
PlatinumPresto.info's Avatar
Talking Pictures of FC wheel fitment with specs... ***Picts-n-Specs ONLY***
f- 16x8 +30 Japanese 2piece Hero's racing, 20mm over fenders
r- 16x8 -15 Japanese 2piece Demon cambers, ??mm over fenders(forgot)
Old Oct 21, 2007 | 10:27 PM
BoostinmyS5
18x10-6
19x10-16
other wheels are:
17x10-2 front (20mm spacer) under 25mm wide fender
18x10.5-5 rear (20mm spacer) under 50mm wide fender
18x11-9 work meister (no spacer)
Old Oct 21, 2007 | 10:30 PM
vipers
18x7.5 38 offset 2.25" lip front
18x9.5 35 offset 3.25" lip rear
Beezy
18x9.5 rear ET 30
18x8.5 front ET 35
Plus 25mm spacers
Old Oct 21, 2007 | 10:34 PM
LeeTheSlacker
18x7.5 +24 215/35/18 federal ss595 (300c wheels)
Old Oct 21, 2007 | 10:35 PM
demontwig
Zenneti aluminum wheels with Falken ZE512 235/45/z18 8.5 front 265/45/z18 9.5 rear with 25mm spacers up front. Stance GR coilovers. A little bit of rubbing when turning too sharp, but otherwise fit fine.
Old Oct 21, 2007 | 10:36 PM
Old Oct 21, 2007 | 10:38 PM
Andrew777
Motegi touge 18X7.5 in the front and 18X9 in the rear
Old Oct 21, 2007 | 10:43 PM
unicorn_squad
16x8 minus 30 front,
16x8 minus 16 rear. after spacers....
205/50 all around.
rotorhead_izzy
hers mine, 18 inch at italia flash's:
Old Oct 21, 2007 | 10:45 PM
ramblux
18x10 +17
18x10 +/-0 215/40
Old Oct 21, 2007 | 10:46 PM
fc3schick87
believe they are 19
Old Oct 21, 2007 | 10:48 PM
Bounter
Rota GTR (P45-R)
Front: 18x8.5" 215/40
Rear: 18x9.5" 235/40
No spacers, only Tein Superstreet coilovers.
real nismo lmgt4's, not the rota knockoffs.
17/18 stagger.
Old Oct 21, 2007 | 10:51 PM
Mills
18x8 +38 offset 225/40 front
18x9 +38 offset 275/35 rear
Old Oct 21, 2007 | 10:56 PM
unicorn_squad
18x9.5 + ~ 12 with 215/35
18x10 +2 with 225/40
18x9.5 +22 with a 225/40 tire. on the front
Old Oct 21, 2007 | 10:57 PM
Furb
18 x 8,5J offset 25 front, 18x x9,5J offset 25 rear
Old Oct 21, 2007 | 11:01 PM
delSkunk
sportmax 962's 17x7 +38 with 5.5mm spacer 225/45 -- 17x9 +35 275/40. tires are bfg gforce sport
Old Oct 21, 2007 | 11:04 PM
azncmb
wheels: work vs-kf
size:
F- 18x9.5 +7(effectively +0 with 7mm spacer to clear caliper).
R- 18x10 +7
tires:
F- 225/40/18 Federal ss595
R- 235/40/18 Federal ss595
stock fenders, with a a roll/pull in the rear...
^^sheet of paper clearence between caliper and wheel spoke ^^
Old Oct 21, 2007 | 11:10 PM
hurleysurf24
Wheels are
17 x 8 - 32 offset
17 x 9 - 32 Offset
225/45/17 on the front
245/40/17 on rear
275/40/17 were rubbing against the mufflers of my racing beat exhaust .. even after the shield was bent. 255/40/17 will make the rears look more flush with the fender.
17 x 8 35offset on the front
Old Oct 21, 2007 | 11:12 PM
RETed
17" x 8.0", +35 wheel
On stock-type shocks, the lower spring perch will interfere with 225 / 235 wide tires.
There is no way it's going to fit without hitting the lower spring perch.
17" x 8.0", +30
235 / 45 / 17 tire
Old Oct 21, 2007 | 11:17 PM
90rx7newbie
17x7
40mm offset
1/4" spacers in front
tanabe lowering springs
225/45/17 front
255/40/17 rear
Old Oct 21, 2007 | 11:23 PM
Rishie
16x8 +32 and +25
stock FENDERS
245/45/16 all around
STANCE COILOVERS.
Old Oct 21, 2007 | 11:24 PM
trueimport
9.5 +35 and a 275
Old Oct 22, 2007 | 12:07 AM
MaczPayne's Avatar
Mac Attack
Nice sizes.
