Knightsports EBS III
Diamond Cut Seven
on
1 Post
Anyone have any info on this? I installed it but don't know what all the modes are. I'm assuming that .60 is the boost aka bar. What are the other two modes? One displays negative and then switches to positive. The other is set at 0.00 is there two settings for the primary and the secondary?
Got Rotors?
on
The first mode acts as a boost gauge. The negative is vaccuum and positive is boost.
Second mode is boost setting. .60 is the default setting.
Third mode is still a mystery to me too.
DaleClarks website had an install and operating guide but the site is down.
And FYI, it actually reads in Kpa and not BAR. 1 Bar = 14.7psi 1 Kpa = 14.22psi Not much of a difference but a difference non the less.
Edit: I almost forget the rest. There's a little block that lights up to the right of the readout, not to get confused with the negative sign when in vaccuum, when the boost control is on. The upper left button turns it on and off.
And to check the peak boost, press the upper right button.
To clear the peak boost, press the lower right button. It remembers the peak boost even after you shut the car off so remember to clear it before any runs.
Hello-
I am looking for (english) instructions for mounting and operation of this boost controller?
If you can't help, what is a contact (email) of the guys in LA?
Thanks,
Mark Koontz
Thanks,
Mark Koontz
