help ted ..or anyone else ..quick question !
Old Apr 9, 2002 | 05:36 PM
i need to know if the boost pressure sensor and knock control box from a S4 will work on an S5 . thanx
Old Apr 9, 2002 | 07:06 PM
RETed's Avatar
Aren't the plugs totally different?&nbsp The knock box is not that important, cause the ECU ignores it after 4kRPM...
-Ted
Old Apr 10, 2002 | 03:27 PM
reted , do you think it would be safe to just not have a knock control box ? thanx
Old Apr 10, 2002 | 03:38 PM
RETed's Avatar
The knock control is a joke.&nbsp The ECU ignores the input after 4kRPM, cause the engine is too noisy at those RPM's.&nbsp It's really only to retard timing due to knocking during cruising on the freeway; it won't save you at WOT.&nbsp The knock sensors tend to melt it's black epoxy fill and make a mess!&nbsp I removed mines cause of this...
-Ted
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
