20b TPS sensor pin out needed
Old Oct 2, 2007 | 10:50 PM
CMonakar's Avatar
rebreaking things
Does anyone have a pinout for the 20b TPS sensor? Please be clear on the orientation. I 'attempted' to set mine up using the wide range output with info that has been passed down by email through several people and the voltage goes up, down, and back up when going from 0-100% open.
Old Oct 5, 2007 | 08:16 PM
IronMdnX's Avatar
Glutton for Punishment
Here you go.
Old Oct 5, 2007 | 08:43 PM
CMonakar's Avatar
rebreaking things
Thanks! I seem to be saying that a lot to you .
Old Oct 5, 2007 | 08:44 PM
teachermechanic's Avatar
I thing it's more like this for the 20B TPS.
1= 5v
2= not use
3= grnd
4= sig
Old Oct 6, 2007 | 11:34 AM
Jeff20B's Avatar
Lapping = Fapping
I agree that the HITman pinout is a little off. At least mine was different from that diagram.
Old Oct 6, 2007 | 02:50 PM
CMonakar's Avatar
rebreaking things
Which sensor pin is 1? The cosmo pinout didn't work for me. Separately, how do you guys have the sensor orineted; is the connector facing the driver side or pas side?
Thanks,
Chris
Old Oct 6, 2007 | 05:17 PM
IronMdnX's Avatar
Now i'm curious. I'll check mine when i get back home.
Old Oct 6, 2007 | 06:34 PM
Thanks,
Chris
#4 is on the top side of the pic.
Old Oct 6, 2007 | 11:06 PM
j9fd3s's Avatar
Community Builder
i remember with mine, i looked up the S5 fc, and the FD pinouts, and had to verify em, turned out to be the same as the fd, and the wire colors even matched (i have the 20b harnesses)
also remember the fd tps is on the REAR of the tb, and the cosmo is on the front, maybe this is the confusion?
Old Oct 7, 2007 | 03:47 AM
bcool's Avatar
Rest In Peace Dave
Originally Posted by IronMdnX
Here you go.
Since we're on this is this the same as the REW motors?
Old Oct 7, 2007 | 09:13 AM
CMonakar's Avatar
rebreaking things
Mine was different than the 13B diagram. I don't want to go from memory so I'll post up the pinout later when I have my log book in front of me. Thanks again.
Old Nov 6, 2022 | 04:39 PM
Azhillman's Avatar
20B TPS Diagram
I know this is an old thread, but I thought I would leave this here to help anyone that needs it.
Old Oct 3, 2024 | 02:35 PM
SankakuJC's Avatar
New to the Club!
20B-REW TPS pinout confirmed
I've just gone through troubleshooting my TPS and confirm that AZHillman and his nicely labelled photo are indeed 100% correct. Decades of wrong information in here, but I've back probed the ECU harness and tested continuity to each of the labelled pins and this is correct for the 20B-REW in a JC Cosmo.
On that note, does anyone know of an alternative TPS that is compatible with the 20B's throttle body and the JC's harness/ECU? Mazda has discontinued NF01-18-911. At the time of writing this Atkins appears to have 2 in stock but they're egregiously priced ($550).
Old Apr 5, 2026 | 09:48 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Greetings everyone, im definitely not posting much on here these days, but i was looking for this Cosmo/20B Pinout, i have confirmed that the old Haltech / Hitman graphic that's available in a few places and in the Haltech Support pages, has the pin locations in the correct placements, but, the text/colors indications are incorrectly positioned. For everyone's benefit, here is an updated TPS pinouts for FC/FD/Costmo/20B. The 'Narrow' signal isnt usable with most engine management systems which is why i've left them and other signals as "Not Connected".
Cheers.
Old Apr 15, 2026 | 03:47 AM
EFI Tech Wannabe
Cheers.
Ok, i needed to correct something on this. So this first one was incorrect. Here is the final version with proper original 20B Colors. If anybody wants to upload a pic of their original throttle connector and the wire colors to verify please do! Cheers!
Old Apr 15, 2026 | 09:10 AM
EFI Tech Wannabe
This image is incorrect. Ive gone even further and tracked down an original harness connector with original colors to verify with the factory manual, this is 100% correct and verified now. Side note, the Haltech / Hitman graphic is correct with positions but NOT the colors. So keep that in mind.
Old Apr 15, 2026 | 01:20 PM
Azhillman's Avatar
I can not speak to the factory wiring diagram for the Cosmo, but I have checked the sensor on my throttle body and confirmed what I posted.
This would be for 0 - 5v for 0 - 100% throttle and is the the way mine is wired to an Elite 750
20b240z
20B Forum
40
Oct 11, 2020 03:49 PM
PeterFd
20B Forum
Sep 18, 2016 10:30 PM
nn20b
Haltech Forum
Dec 16, 2007 08:21 PM
