Pump + tank. Trunk install pic request
Old Sep 17, 2007 | 09:22 AM
efiniste's Avatar
Anyone got a pic of their trunk setup or point me in the right direction? I've done a search but come up with very little.
I've just got an HFS-5 setup but the tank that came with it is way too tall for the trunk of an FD. Thinking the coolingmist tank with built in pump mount might be a good option. I've also got a UK spec rear washer bottle but I'm not convinced it's the right shape to avoid starvation problems (it mounts across the rear of the car and is probably 6-8 times the size of the standard one).
Any other options out there?
thanks,
Steve
Old Sep 26, 2007 | 11:22 PM
tom94RX-7's Avatar
Here is my AEM kit I just installed. I spent quite a while thinking and trying to find a decent place to mount these, this spot worked out well. Notice my bracket I made for the tank, bracket attaches to one of those studs back there, and one more screw to secure the bracket to the trunk floor, and how I used 2 screws to mount the pump.
Attached Thumbnails Pump + tank. Trunk install pic request-water-meth-injection-003.jpg   Pump + tank. Trunk install pic request-water-meth-injection-006.jpg   Pump + tank. Trunk install pic request-water-meth-injection.jpg
Old Sep 27, 2007 | 05:44 AM
efiniste's Avatar
Thanks for that. The tank looks to be the same as the one I have with the HFS-5. Have you dropped the bottom of it into the spare wheell well there?
Old Sep 27, 2007 | 06:47 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
take a look at the 2 sticky threads... "optimised installation and pictures of my install"
hc
Old Sep 27, 2007 | 12:06 PM
tom94RX-7's Avatar
Yes, just far enough so there is enough clearence above it, and room for the hose that comes out the bottom.
Old Sep 28, 2007 | 10:52 AM
efiniste's Avatar
Thanks Tom.
Howard, do you run your tank in the spare wheel well? One thread says you do but the pictures in the other thread show it in the trunk.
Looks like I'll be losing my spare at any rate.
Steve
Old Sep 28, 2007 | 10:57 AM
yes, my fuel sits on approx 1 inch of insulation on the bottom of the spare tire recess and extends above the rear carpet. 4 gallon cell...
hc
Old Sep 28, 2007 | 02:59 PM
efiniste's Avatar
Aha! Now it makes sense. The pics make it look as if it doesn't sit in the well at all. Very neat install. Thanks Howard.
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
