Wheel Spacer Question
Old Sep 12, 2007 | 05:19 PM
GtSuper99's Avatar
Ok! Here we go!
I have a 91 FC and I brought a set of wheels 17x8 with +45 offset.
I need to throw on a set of 10mm spacer. My question is...
1) Do i need to extend my studs?
2) if so, what's the length of our current studs?
Someone respond please, I'm dying to put them on.
Old Sep 14, 2007 | 06:20 PM
Josh18_2k's Avatar
go to summit or wherever and buy ARP late model camaro/firebird studs. they're cheap enough, you'll get em in a couple days.
they look badass- they're a bit longer and gold. the fronts will be just right, but in the rear they are like an inch longer than necessary, so you'll need open ended lugnuts.
oh btw- changing the rear studs requires destruction of the wheel bearing. so you'll need a new set of those too.
Old Sep 14, 2007 | 06:29 PM
aznpoopy's Avatar
strike up the paean
or get spacers with studs pressed into them
Old Sep 14, 2007 | 08:06 PM
Black91n/a's Avatar
15mm spacers would yield a better offset.
Old Sep 15, 2007 | 07:26 AM
Wezzmo's Avatar
grab some 20bolt on spacers..
done.
diabolical1
30
Jan 30, 2016 05:50 AM
