My oem part numbers thread..
Old Apr 7, 2002 | 09:22 AM
Maxthe7man's Avatar
Freedoms worth a buck o'5
Lightbulb My oem part numbers thread..
I am sick of speedshops that know nothing about turbo's, stock nothing, and don't know where to get it, I am becoming amazingly good at finding the parts I need through oem dealerships of other vehicles, I also am sick of searching the web for hours for a part number and never finding it, so I am gonna start my own little thread here, of all the info and part numbers I come across while I piece together my T04E TII..
If you have a relevant number to add, then add it, if not, don't..
TO start with, Ford heavy truck part number for to4 divided manifold gasket, available from Freightliner/Sterling/Ford
DLM/E7HZ6N640A Gasket,Turbo $7.57 (canadian)
Old Apr 8, 2002 | 03:51 AM
Dragon's Avatar
20B N/A Wide Body FC3S
These are all FD parts except the FC O ring kit I use them because they are about a $100+ cheaper and have every thing you need to overhaul a fd... Some of the part #'s are from the 2001 FD manual which has metal gaskets for the front cover etc instead of paper..
Enjoy..
Item Part # Price
Pilot Bearing N326-11-D03 ¥ 940
Pilot Seal 1881-11-404 ¥ 170
FC O’ Ring Kit N318-10-S60A ¥ 9,290
Apex Seal N3F1-11-C00 ¥ 2,800
Apex Seal Spring (L) N326-11-C06C ¥ 320
Apex Seal Spring (S) N326-11-C04A ¥ 370
Side Seal N3Y1-11-1C11 ¥ 590
Side Seal Spring NF01-11-C17 ¥ 240
Corner Seal N326-11-C20A ¥ 370
Corner Seal Spring NF01-11-C24 ¥ 100
Oil Seal #1 0820-11-341 ¥ 540
Oil Seal #2 8341-11-343 ¥ 890
Oil Seal Holder 8871-23-180 ¥ 2,860
Oil Seal Springs (I L) N225-11-361 ¥ 320
Oil Seal Springs (I R) N225-11-351 ¥ 320
Oil Seal Springs (O L) 1011-11-363A ¥ 320
Oil Seal Springs (O R) 1011-11-353A ¥ 320
Throttle Body O-ring N390-13-W69 ¥ 910
Throttle Body Gasket N2A1-13-655 ¥ 800
Front Cover Gasket N390-10-502 ¥ 1,950
H20 Pump Hsing Gasket N386-15-162 ¥280
Upper Manifold Gasket N3A1-13-112 ¥ 680
Secondary Injector Diff N3A1-13-C60 ¥ 1,220
Primary Injector Diff N3A1-13-C61 ¥ 1,260
Front Cover Main Seal N3A1-10-507 ¥ 730
Rear Main Seal 1668-10-556A ¥1030
Item Part # Price
Rotor Bearings
3.000 (-0,005 - -0.010) N3A1-11-B11 ¥ 2,340
3.000 ( 0.000 - -0.005) N3A2-11-B11 ¥ 2.340
3.000 (+0.005 - 0.000) N3A3-11-B11 ¥ 2,340
Stationary Gear Bearings
T=1.980mm yellow NF01-10-E04 ¥ 3,270
T=1.983mm green NF01-10-E05 ¥ 3,270
T=1.986mm brown NF01-10-E06 ¥ 3,270
T=1.989mm black NF01-10-E07 ¥ 3,270
T=1.992mm blue NF01-10-E08 ¥ 3,270
T=1.988mm yellow NF01-10-E22 ¥ 3,270
T=1.991mm green NF01-10-E23 ¥ 3,270
T=1.994mm brown NF01-10-E24 ¥ 3,270
T=1.997mm black NF01-10-E25 ¥ 3,270
T=2.000mm blue NF01-10-E26 ¥ 3,270
Station Brng Lock Screw NF01-10-E09 ¥ 330
Old Apr 8, 2002 | 07:16 PM
j9fd3s's Avatar
Community Builder
3.5mm vacuum caps 1010-13-104
ast removal "kit" N326-15-17YA + N326-15-174
mike
Old Apr 11, 2002 | 12:01 AM
Maxthe7man's Avatar
Garrett turbo family breakdown:
04G35S
Aug 14, 2015 07:31 AM
