S/4 convertible wont hold idle!
Old Sep 9, 2007 | 10:43 PM
TOOSHORT_88's Avatar
"On the grind"
Unhappy S/4 convertible wont hold idle!
Yes ive searched and just found peeps having problems with 7's not holding idle but there problem is pushing on gas pedal wont matter,still wants to die.
MY vet starts just fine rpms go to 3k then will drop slowly (2-3 sec) to 2k then after that it drops radidly and then dies. She will idle wen i step on gas pedal and make her idle thats not a problem, also driving in gear is perfect, just wont hold an idle what so ever.
I just replaced the afm just to make sure it wasnt faulty wen the problem arrised, made no diff from previous afm.
Just eliminated the stock air box, all vacum lines on rubber pipe are all connected , replaced the o2 sensor 3 months ago wen i put on pacetter header.
Afm is not sitting at an angle its level and not upside down.
ben driving her for 3 months with pacetter header and main cat has good size exhaust leak, but never caused her to die, idled lil bit ruff but never came close to dieing out with the exhaust leak.
Tried to start her up today and engine was cold , revd to 3k then wanted to drop i held gas pedal about 10 sec's or so, she idled for about 1 min then then dies out.. I noticed my header was glowing orange is that normal wen engine cold?
any help is helpful
thks jason
Old Sep 10, 2007 | 12:31 AM
"On the grind"
Old Sep 10, 2007 | 12:34 AM
rx7-kid's Avatar
Incomplete Project
You sure its not a vac leak. check the hose that came off the intake pipe. dont know what it's call.
Old Sep 10, 2007 | 06:04 PM
"On the grind"
its all plugd in, anyone else got idea?
Old Sep 10, 2007 | 06:20 PM
Brody8877's Avatar
#FakeCarEnthusaist
check your BAC, make sure AFM is leveled, make sure your getting fuel, and make sure your TPS is calibrated correctly.
Old Sep 10, 2007 | 06:38 PM
Lizo7's Avatar
cat clogged?
Old Sep 10, 2007 | 10:45 PM
"On the grind"
all is level , how to check the bac?
long story short: put on new intake , started fine idled fine , drove thru stop and go traffic for 20 min no problem , got on freeway drove for about 7 miles as soon as i took my exit i noticed that the car was off, thats it,.
After that the car would not idle for nothing...
Old Sep 11, 2007 | 04:44 PM
"On the grind"
Come On Anyone Help With Info
Old Sep 12, 2007 | 07:40 PM
"On the grind"
No Love For The Vert?
Old Sep 12, 2007 | 09:12 PM
Ballin_is_a_Habit's Avatar
legalize it
ghetto compression test it
Old Sep 12, 2007 | 09:52 PM
"On the grind"
drives fine just idle wont hold up
Old Oct 19, 2007 | 04:12 AM
brandonn's Avatar
i don't know if this will help or not because the symptoms are quite different. Everytime i braked hard, my car would shut off. it turns out something was stuck in my throttle body. took it out and car worked fine.
Old Oct 19, 2007 | 08:15 AM
pfsantos's Avatar
(blank)
Odd...use some propane in a bottle (those torch kits) and spray a little around the engine. Vacuum leaks show up as a rise in idle. BAC valve can be checked with a multimeter (see FSM in my sig.).
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
Gian
Race Car Tech
Sep 8, 2015 09:23 AM
Frisky Arab
Sep 4, 2015 06:17 PM
