Distributer, points or electric
Old Apr 6, 2002 | 06:50 PM
jeremy's Avatar
male stripper
Alright, i'm stupid about older cars. the inside looks new so i was wondering if maybe the distributor had been switched to electronic.
jeremy's Avatar
male stripper
and second
Old Apr 6, 2002 | 07:08 PM
hanman's Avatar
Jeremy,
I am not sure what your question is? The only RX to come with the old points style distributor was the 79 model. In 80 they switched to electronic distributors with the ignitors mounted seperately. In 81 they upgraded the distributor with the ignitors mounted on the distributor.
hope this helps,
hanman
Old Apr 6, 2002 | 07:13 PM
jeremy's Avatar
male stripper
mine is a 79. it originally would have had points. but this dizzy looks newer. i don't know how to tell the difference so i posted pics for you gurus to tell me which it is.
Old Apr 6, 2002 | 07:24 PM
mar3's Avatar
Administrator
No ignitors, so it's either a '79 or '80....take a photo like your first one, but pull the rotor off. If it's got paddles on the shaft and a sensor close but not touching the paddle ears, it's electronic. If it has two thingeys (gotta love the scientific language... ) with little blocks that actually touch the center distributor shaft, then you've got the stock old school points system. Ditch it as fast as you can if that's the case, amigo!!
Old Apr 6, 2002 | 07:33 PM
jeremy's Avatar
male stripper
ah i see. i gotta take off the spinner. does it just pull off?
Old Apr 6, 2002 | 07:38 PM
mar3's Avatar
Administrator
It'll resist a little, but yes, it pops right off. When you go to putting it back on, make sure you have the "D" shape of the shaft and the spinner's hole lined up before you shove it back down.
Old Apr 6, 2002 | 07:43 PM
jeremy's Avatar
male stripper
gotcha
Old Apr 6, 2002 | 09:11 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Updating that to a electronic is very easy. Its just 4 wires and a new dizzy. I think the coils may be the same ? Not sure?
Old Apr 6, 2002 | 09:14 PM
V8kilr's Avatar
yeah i think the coils are the same,
it just has the ignitors soemwhere by them,
instead of on the sides of the dizzy,
i would actually prefer a dizzy like that for a direct fire setup,
i still dotn feel to comfortable with the wires going to my leading ignitor
Old Apr 6, 2002 | 10:41 PM
79+80_rx-7's Avatar
Yeah, thats points I know cause I have seen both the type of rotors The electronic rotor is taller, and the points look like the on in the pics. Plus the lettering on the cap is different between the two. The 79 looks like the one in the pic, and 80 looks like the one in my 79
LATERZ, Andrew
Old Apr 6, 2002 | 10:48 PM
jeremy's Avatar
male stripper
ok, kilr, you get to help me set up a direct fire when you get down here.
Old Apr 6, 2002 | 11:14 PM
riffraff's Avatar
smog nazi destroyer
which dizzy are you refering to?
Old Apr 6, 2002 | 11:29 PM
mar3's Avatar
Administrator
I think he means a dizzy without the ignitor pads cast in it...
Old Apr 7, 2002 | 12:07 AM
V8kilr's Avatar
bingo,
reread my post,
you will understand
Old Apr 7, 2002 | 12:15 AM
V8kilr's Avatar
no problem,
we gotta get you a new dizzy if your is points though,
i wander if the one on the doner will fit???
search?
anyway here is my check list before i can make the trip,
get msd wires "should have on tuesday"
rewire the whole back half of my car "just redid the whole part under the dash on driver side and a ton in the engine bay, should have from the seats back done by thursday,depending on weather"
install my new racing beat exhaust "one problem though,my new muffler is a dtm style, im afraid that when i put on that rear bumper off the doner it may interfere with my muffler"
install new rear sway bar
install new trailing arm lower link
reprime car in black
get license back "a must"
get some stuff mailed out to buyers on ebay "they will be pissed if i wait till i get back"
oh and im also going to need to yank those struts when i come down,
the only way im gonna get that body kit back is if i install it,
my front end sits about 1.5" off the ground,
i wouldnt even make it down the road,so i will ned to raise it back to stock height with the doner struts
im rushing to get this all done in a week,
i have acomplished quite alot in the past couple days,
im on a pretty good roll.
everyone wish me luck
Old Apr 8, 2002 | 06:07 PM
V8Kilr and Mike P-28:
The coils are not the same. I read on the mazspeed site that if you use old 9 volt coils, the new current or voltage needed by the electronic distributor will fry them. The site says to pick up MSD Blaster coils for $33 a piece and save yourself the long walk home.
"The journey of a thousand miles...starts with a broken fan belt and a flat tire"
Remember, this is what I read at mazspeed. I am waiting on a donor engine to do this to my car, so I am not speaking from personal experience.
Old Apr 8, 2002 | 06:42 PM
jeremy's Avatar
male stripper
i have a jacobs street kit. control unit and a large 30k volt plus coil. i just didn't want to deal with the wiring it in points sytle. i actually i just didn't want to deal with wiring it in period but last time i did it it was on an electronic distributor. the leading coil was oozing goo when i bought the car.
damn kilr, thats a lot of **** to do. if the rear valance doesn't clear the muffler then we'll just adapt the hangers and lower your exhaust in the rear.
23Racer
Race Car Tech
Sep 21, 2015 10:48 AM
firzen
Sep 15, 2015 12:04 PM
