Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D V500: need help
Old Sep 3, 2007 | 10:54 PM
gdudley's Avatar
V500: need help
I just got my new V500 hooked up on my project car. It is an S4 turbo based FC3 with a massive intercooler and 3" turbo back exhaust and FD ignitors. Most other is stock. I need a base map so I can drive to the dynoshop which is app. 15 miles from my home. I've found many for the V4, but none for the V5. If anyone knows where I could find something, help. Thanks
Old Sep 3, 2007 | 11:41 PM
nyt's Avatar
nyt
just copy the settings and do a rough copy of the fuel map.. also when asking for a map its generally a good idea to list things like injectors and fuel pressure as well
Old Sep 3, 2007 | 11:44 PM
gdudley's Avatar
Oh yeah, no cats or emissions either. There all stock for now. Will the .WMF files for the V4 work because the V5 ones are .EMS?
Old Sep 4, 2007 | 08:03 AM
Michael Smith's Avatar
Talking
No .... V4 and V500 are nothing alike ....what size injectors ...CAS type how are the injectors wired these all matter. I can rough up a map if I have enough detail and it is wired and plumbed right.
Cheers
Michael Smith
Old Sep 9, 2007 | 07:22 AM
nn20b's Avatar
be careful....my v500 burned up last night. I was testing timing and saw smoke coming out of the ecu. 5 seconds later, the ecu died. POS
I should have went with a haltech.
Old Sep 9, 2007 | 08:09 AM
OUCH!
What do you think happened??
Michael Smith
Old Sep 9, 2007 | 02:39 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
contact wolf, if it was infact a problem with there ecu, they will replace it
Old Sep 9, 2007 | 07:07 PM
nyt's Avatar
nyt
lol maybe you wired something wrong
Old Sep 9, 2007 | 09:39 PM
nn20b's Avatar
Originally Posted by Michael Smith
OUCH!
Michael Smith
not sure....nothing changed since we last discussed. I suspected something wrong with this ecu from the start and it never worked right.
Hopefully Wolf will replace/repair it.
In the mean time, I will turn attention to my daily driver, 05 STi.
Old Oct 26, 2007 | 04:28 PM
20B3rdgen's Avatar
Did anyone put together a base map yet? I also need one.
