Blitz SBC iD-III Boost Controller
Old Sep 2, 2007 | 01:11 PM
bluesi's Avatar
Calling out to all who are using this boost controller, I need your help.
There is a (3) wire harness between the controller and the solenoid valve unit. The wires are coloured blue, purple and white.
One of the (3) wire should be the +12V supply common to the two solenoid coils. The other two should go to the "switch to ground" of the solenoid coils.
If you unplug the three pin connector form the controller first, measure the pin on the controller socket until you see a 12V with a multimeter, I need to know which is the wire that does this.
Thank you!
Old Sep 2, 2007 | 05:26 PM
skir2222's Avatar
I win
Did you try going to blitz's website and look up the manual? That may help you out...
