Turbo Control Solenoid Wire Color
Old Aug 31, 2007 | 06:47 AM
Sr20fd3st's Avatar
I'm going back to sequential, but I had previously cut out all the original connectors. I bought a new section of harness and put a 16 pin plug on it and im doing the same to the original harness piece. anyway, the wire colors in the 94 wire diagram seem to be different than those of my 93 fd, so it's not much help. I need to know what the wire colors are for a 93 for the turbo control 1, turbo control 2, pre control solenoid, wastegate solenoid, charge relief solenoid, charge control soneloid, and also the fuel pressure control solenoid (I know this used to have the orange connector if this helps. If no one knows this, then maybe what solenoids go to what pins at the ECU so i can find them through testing for continuity.
Thanks,
Oliver
Old Aug 31, 2007 | 09:04 AM
Mahjik's Avatar
Mr. Links
Is this what you need?
https://www.rx7club.com/3rd-gen-archives-73/color-connectors-solenoids-582230/
Old Sep 5, 2007 | 02:50 PM
Sr20fd3st's Avatar
eh, lol just ended up testing all the connections for continuity to their resepective ecu pins. now my car is sold, and the world is a better place
sherff
Feb 24, 2019 12:09 PM
