Microtech Somebody have the base stock map for tII
Old Aug 22, 2007 | 08:00 AM
wilcar's Avatar
Newbie
Exclamation Somebody have the base stock map for tII
Somebody have the base stock map for tII. I need to make this car run. Runs to rich.
Old Aug 23, 2007 | 06:19 PM
13bturbofc's Avatar
mmm doritos
This Is for a s5 TII stock 550cc FI's. Mods listed at the time of purchase (If this matters) are: big streetport, FMIC, full 3" ss Exhaust no cat, Walbro.
Idle Map
Screen 1
30" ~ 1.33
25" ~ 1.48
20" ~ 1.93
15" ~ 2.38
10" ~ 2.48
05" ~ 3.48
00" ~ 4.0
2-20psi ~ 4.95
Load Map
Screen 3
30" ~ 1.76
25" ~ 1.86
20" ~ 1.95
15" ~ 2.24
10" ~ 2.90
05" ~ 3.90
00" ~ 4.81
2psi ~ 5.62
4psi ~ 6.10
6psi ~ 7.14
8psi ~ 7.86
10psi ~ 8.48
12psi ~ ???
14psi ~ 8.71
16psi ~ 9.00
18psi ~ 9.48
20psi ~ 10.00
RPMwot Map Screen 17 &
RPMcrs Screen 18 expressed as a percentage with all values set at zero.
Pump Map
Screen 19
Pump2Start ~ 2000
Pump1Amt ~ 10
Pump1Pulse ~ 02
Pump1Trig ~ 14
Pump1Stop ~ 00
Pump1Adv ~ 05
Pump2Time ~ 10
Pump2Amt ~ 30
Pump2Trig ~ 16
Pump2Stop ~ 00
Pump2Adv ~ 05
PumpDwell ~ 3.00
PumpTimers ~ No
Pump1Sync ~ No
PumpSpare ~ 00
PumpCold ~ 00
Water Map
Screen 20
-25 ~ 0
-17 ~ 70
-9 ~ 60
-1 ~ 55
5 ~ 50
11 ~ 50
18 ~ 45
24 ~ 35
31 ~ 30
38 ~ 20
46 ~ 15
60 ~ 12
68 ~ 8
82 ~ 0
99 ~ 0
124 ~ 0
Air_t Map
Screen 21
-25 ~ 0
-17 ~ 8
-9 ~ 6
-1 ~ 5
5 ~ 4
11 ~ 3
18 ~ 3
24 ~ 0
31 ~ 0
38 ~ 0
46 ~ 0
60 ~ 0
68 ~ 0
82 ~ 0
99 ~ 0
124 ~ 0
Crank Map
Screen 22
-25 ~ 72
-17 ~ 72
-9 ~ 72
-1 ~ 67
5 ~ 62
11 ~ 57
18 ~ 50
24 ~ 41
31 ~ 31
38 ~ 26
46 ~ 20
60 ~ 15
68 ~ 5
82 ~ 0
99 ~ 0
124 ~ 0
t*rpm
Screen 23
Idle ~ 00
1000 ~ 10
1500 ~ 15
2000 ~ 20
2500 ~ 25
3000 ~ 25
3500 ~ 25
4000 ~ 25
4500 ~ 25
5000 ~ 25
5500 ~ 25
6000 ~ 25
6500 ~ 25
7000 ~ 25
7500 ~ ??
8000 ~ 25
9000 ~ 25
t*map Map
Screen 24
Idle ~ 00
25 ~ 05
20 ~ 04
15 ~ 03
10 ~ 02
05 ~ 00
00 ~ 00
2psi ~ 00
4psi ~ 00
6psi ~ 00
8psi ~ -02
10psi ~ -03
12psi ~ ???
14psi ~ -04
16psi ~ -05
18 psi ~ -06
20 psi ~ -06
t*air Screen 25
Correction value Is expressed as number of degrees you wish to advance or Retard to the Ignition curve and values Is set at zero.
t*gap
Screen 26
0500 ~ 15
1000 ~ 15
1500 ~ 15
2000 ~ 14
2500 ~ 12
3000 ~ 10
3500 ~ 10
4000 ~ 10
4500 ~ 10
5000 ~ 10
5500 ~ 10
6000 ~ 10
6500 ~ 10
7000 ~ 10
8000 ~ 10
t*Inj Map
Screen 27
0500 ~ 120
1000 ~ 150
1500 ~ 150
2000 ~ 150
2500 ~ 150
3000 ~ 150
3500 ~ 180
4000 ~ 180
4500 ~ 210
5000 ~ 210
5500 ~ 210
6000 ~ 240
6500 ~ 240
7000 ~ 270
8000 ~ 270
9000 ~ 270
t*wat Map Screen 28
Option Map
Screen 30
Af_StE ~ 10
Dwell ~ 3.00 *set at Time Base - not at Duty Cycle*
REVstg ~ 3000
MAPstg ~ 05"
%stg ~ 50
I hope this helps
Old Aug 23, 2007 | 06:20 PM
13bturbofc's Avatar
mmm doritos
i got this from the sticky at the top of the list in the microtech section..check it out
Engine Management Forum
11
Nov 9, 2015 01:15 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
20B Forum
Aug 19, 2015 01:47 PM
