Help- new engine dies at 4000RPM!!
Old Apr 4, 2002 | 04:49 PM
quick 7's Avatar
That thing got a Wankel?
Ok, I just finished putting in a new engine into my RX, it runs great up to 4000RPM then its cuts out and sputters and almost dies, it refuses to go over this RPM. Anyone have any Ideas on the problem and a fix? thanks for any help
Old Apr 4, 2002 | 05:01 PM
Bambam7's Avatar
I came, I saw, I boosted.
It's pretty apparant that your secondary injectors aren't coming online.
OR- you have very bad compression- OR your cat is clogged (if you have one)
I'm guessing it's probably your secondary injectors.
Check the plugs, and check the ground from under the intake manifold, to the firewall. Actually, run a new one anyways- a heavier gauge. That ground is crap, and usually lead to the 3800 rpm problem.
I would check the voltage on those injectors by the ECU harness.
It's under the passenger floor mat- it's easy to get to, and easy to check the voltages.
Do two things. Check the voltage with a multimeter from the o2 sensor while driving. (I can't remeber which pin- the #'s are at www.fc3s.org)If it drops below .70 V when power cuts out- it's leaning out. meaning no fuel.
Second, check the seondary injector voltages at the harness, they should drop from about 13V to 11, at 3800 RPMS... and should drop farther the highre RPMS you get (more duty cycle on injector)
If you determine it's the injectors, then see where the wiring problem is (plugs, at ECU, in wires, grounding... etc)
Good luck!
Dan
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
rotor_veux
Aug 23, 2015 09:06 PM
86glxNA
Aug 22, 2015 08:54 PM
