Far East Forum Serving Asia and surrounding Areas. Far East users, post event and club info here
RE-Amemiya Redom ECU N3A7 18 881B What type is it?
Old Aug 14, 2007 | 04:26 PM
Copeland's Avatar
32psi+
I have a RE-Amemiya Redom ECU (N3A7 18 881B) and was wondering if anyone could tell me which type it is. Thanks!
-Aaron
Old May 12, 2008 | 09:18 AM
Rotaconz's Avatar
Re amemiya redom
Hi there it's the Type - A redom
I have the same one.They're very good
Old May 12, 2008 | 09:26 AM
Rotaconz's Avatar
The TYPE-A ROM tune from Amemiya is for fully stock to lightly modified RX-7`s. If you are aiming for 285hp~310hp with your Rotary Rocket, this ECU can handle it. The Type-A unit is for those using emission (JASMA) type mufflers (with the catalytic converter)
The boost levels on this unit are set at 0.90 bar under 4500rpm and 0.80 bar at over 4500rpm and the secondary turbo will engage at 4450rpm. The boost limiter at above 5500rpm is set at 0.90 bar and the rev limiter has been raised to 8200rpm.
Old Nov 15, 2008 | 01:31 PM
chapter_one85's Avatar
dog eat dog
Can anyone tell me something about this ecu?
Redom ecu with serial number - N3A8 18 881A
what caind of setup does this require and whats the difference towards the original setup?
How much hp can this ecu provide?
Regards
Old Jun 15, 2009 | 06:54 AM
dog eat dog
Now I have bought the redom type ? box and it boosts 1,25 bar that is approximate 17,5 psi, isnt that a little rough? I have a full bpu, but can the motor handle this pressure? I think its weird if it shouldent because its still a re-amemiya mapped box, but who knows.
I would guess that this is a type B Maybe.
I have the old standard fd turbos and Ive heard that the bearings only can handle about 15 psi (safe mode) and over that they shouldent stay alive very long.
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
dillrx7
Sep 7, 2015 09:38 AM
befarrer
Sep 4, 2015 08:26 PM
