Megasquirt Can't get rid of config error (msq posted)
Old Aug 13, 2007 | 12:10 PM
pitchblack7's Avatar
It doesn't matter what I do, I've reflashed the firmware plenty of times, enter all the settings from the faq in, sometimes it works momentarily but in the end I always end up with that flashing fuel pump. I just can't figure this one out, so any help would be appreciated. Thanks.
-Andrew
The msq is not actually zipped, I just changed the file extension to upload it, so just replace "zip" with "msq" to use, thanks.
File Type: zip
Old Aug 13, 2007 | 01:14 PM
renns's Avatar
Go to MegaTune menu Communications -> MiniTerm, and power cycle your MS box. The error is then described on the screen. I did that in your case, and got:
'Config error with spark outputs or wheel decoder trigger settings"
Not very descriptive in this case, but it gives you a place to start. Checking your wheel and output settings, and all is fine. Spark outputs A, B, and C are designated. Going over to Spark -> Rotary Trailing Settings -> Rotary Trailing Settings, we find trailing split support is turned off. This should be turned on. A power cycle now shows proper boot up procedure, with the fuel pump led on for the priming pulse only until a tach signal is seen.
Hope that helps a bit.
Old Aug 13, 2007 | 02:19 PM
Thanks a lot, I really feel stupid now....
-Andrew
renjiv2
57
Jan 25, 2024 03:34 AM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
ZacMan
Sep 19, 2015 09:20 PM
scissorhands
Sep 16, 2015 01:25 PM
