Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D [help] Wolf Wideband LC-1 Install
Old Aug 4, 2007 | 10:50 AM
hwnd's Avatar
watashi no shichi
I've got the unit wired ready for calibration but before i go any further... I've got a question.
I dont want to run a narow-band to the Wolf3D v4 unit to simulate a narrow band oxygen sensor - whats the point in that?
Since my unit is a Plug & Play harness style, I can't follow the manuals directions (wire up pin26 as wbo2 input+ & pin13 ground).
so here i am, stuck, how can i wire the LC-1 for the Wolf3D v4 without simulating wideband and run the LC-1 output to the wolf?
Old Aug 4, 2007 | 01:01 PM
nyt's Avatar
nyt
with a wolf v4, you cant.
the o2 sensor calibration table simply does not work. You can put the settings in all you want, but they do not take (thanks wolf!) If youre using it for datalogging, I'd try to find a 5v input youre not using and "calibrate" it on that.
Old Aug 4, 2007 | 01:03 PM
nyt's Avatar
nyt
This is why you see all my datalogs posted from tewblog =]
the wolf v4 only supports LSM-11 type inputs, which isnt wideband.
good luck.
if you hookup a map sensor and tach output to a logger you get all the important data
http://countercultured.net/pics/logs/log3.png
http://countercultured.net/pics/logs/matrix.png
Old Aug 5, 2007 | 01:28 AM
hwnd's Avatar
watashi no shichi
I understand that - so from this point, I'll need to use the analog-narrow-band-simulator output from the LC-1 to give the Wolf some sense of a/f ratio, right? i mean, it can't live/run without knowing the afr;
as far as the o2 calibration - i wonder if its due to the software not writing back or the ecu doesn't support it but as far as i know - its the softwares fault for that piece... and i bet you $100 i can provide source code to write that out on the eeprom;
Old Aug 5, 2007 | 02:02 AM
nyt's Avatar
nyt
the wolf doesnt give a **** about the a/f ratio unless you have it setup for closed loop. If you can rewrite the o2 calibration table I'd be impressed and it would make a lot of people quite happy.
Also, if anyone can postup the latest v4 software that'd be nice. I only have old versions of it that are buggy.
Also, the non-new wolf software before the big revision would be sweet too being that my disks are toast.
Old Aug 5, 2007 | 10:39 AM
hwnd's Avatar
watashi no shichi
http://www.3rotor.jp/downloads/
I've been hosting these files for a while; hope I've got what you're looking for.
Old Aug 6, 2007 | 06:54 AM
Michael Smith's Avatar
Just put the LC1 in narrowband and use the wolflogger with the narrow band calibration table from the dropdown and log the AFRs then convert them to run on Tweblog
Michael Smith
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
vmerino
Sep 5, 2015 11:26 AM
