ideal tire size for 18x9, 18x10 on FD3S??
Old Jul 26, 2007 | 03:31 PM
SportCoupe2's Avatar
What would the ideal tire size be for the following wheels on a '93 RX7, all stock suspension?
front 18x9, 44mm backspacing
rear 18x10, 44mm backspacing
Second question, what would the maximum width tire sizes be for the same wheels?
Old Jul 26, 2007 | 04:29 PM
purerx7's Avatar
Registered User
i run 285/30 out back with out any rubbing or any problems, i have wide front fenders so cant help you out on the front, this is on a +46 wheel as well.
Old Jul 27, 2007 | 08:13 AM
bump for more input please.
Old Jul 27, 2007 | 09:13 AM
Trout2's Avatar
Not sure if you can run them with +44 offset but ideal is 255/35 and 285/30 (closest to rolling diameter of the original 225/50/16).
Jack
Old Jul 27, 2007 | 09:50 AM
ptrhahn's Avatar
Try 275/35/18 rear, and 255/35/18 front.
The only problem with the 285/30 rear is that's much shorter than a 255/35, and I wouldn't really want a taller front to rear tire. It looks funny, and is going the wrong way as far as the rake of the car... so you'd really want no more that a 245/35 up front.
Here's an example of 275/255... same rim sizes, but +42 offset.
Attached Thumbnails ideal tire size for 18x9, 18x10 on FD3S??-dscn2062.jpg   ideal tire size for 18x9, 18x10 on FD3S??-dscn2064.jpg
Old Jul 27, 2007 | 10:21 AM
So the maximum front tire would be 255/35 and maximum rear would be 285/35 (slightly taller then the front)?
I have two very nice BFG KDW2 265/35 tires, would it be possible to run them on the front with fender rolling? I believe they may be too narrow for the rear 18x10 wheels.
Has anyone run a 295/35 in the rear on an 18x10 +44 offset?
Old Jul 27, 2007 | 10:33 AM
ptrhahn's Avatar
275 is the largest you should go with a 35 series. 285 and higher need to be 30 series (remember, the series is a percentage, not a fixed height). A 295/30 is around the same height as a 255/35, but is a little too wide for a 10" rim.
You can do the 285/30, 255/35 combo, just know that the rear tire will look lower profile than the front... which personall, I don't like.
Old Jul 27, 2007 | 01:38 PM
unicorn_squad's Avatar
265/35 will fit on a 10 no problem. recommended width for that size tire is 9-10.5.
then just run like a 245 in front.
Old Jul 27, 2007 | 02:11 PM
cabaynes's Avatar
Old and grumpy
I run 285/30 in the rear and 255/30 up front with 18x9 +43 and 18x10 +43... When you have the wheels off the car you can see that the rear tires are about half an inch shorter than the fronts, but on the car you really can't tell any difference. Here is a pic:
Old Jul 27, 2007 | 02:26 PM
ptrhahn's Avatar
Looks better than I would've thought Charlie... maybe I'll do 285's next time :-)
Old Jul 27, 2007 | 04:05 PM
If my 265/35 will work up front that would be ideal for me, then I'd just have to buy a set of 285/something for the rear.
I can't test fit right now because my FD is on jackstands getting work done.
Old Jul 28, 2007 | 11:38 AM
gnx7's Avatar
For the street..... the 255/35/18 front and 275/35/18 rear is a great combo. They are also probably the cheapest cost for tires in that size. I ran them on my last FD.
Going to a 285/30/18 nearly doubles the price of the tire.....
Old Jul 28, 2007 | 09:18 PM
I'd like to use my two 265/35-18 tires if possible. Can I run them on the front or do I have to run them on the rear?
What other size tire should I get that would go with these two 265/35's?
Old Jul 28, 2007 | 11:50 PM
cabaynes's Avatar
Old and grumpy
the 265 will be pushing it for the front wheels, especially if you don't have a roll/pull on your front fenders. You could get some 255/35 tires for the front wheels, and throw the 265's on the rear and then upgrade to 285's when the 265's wear out... You *should* wear them out much faster than the fronts, so the 255's you get now would probably still be in good shape when you replace the rears.
Old Jul 28, 2007 | 11:51 PM
cabaynes's Avatar
Old and grumpy
Well thank you! I don't have any closer pics but the sidewall isn't as short as you'd think, and that slight bulge of the tire past the wheel lip looks very aggressive from the rear
Old Aug 1, 2007 | 03:43 PM
Trout2's Avatar
I know about the difference in height b/t the 255/35 and 285/30 on paper but it has never caught my eye on my own car.
Attached Thumbnails ideal tire size for 18x9, 18x10 on FD3S??-100_0816reduced.jpg
Old Aug 1, 2007 | 04:43 PM
darkslide750's Avatar
I was looking at some 285's vs 275's and saw this thread.
Size Diameter Sidewall
285/30/18 - 24.7in 3.4in
275/35/18- 25.6in 3.8in
255/35/18- 25.0in 3.5in
265/35/18- 25.3in 3.7in
255/30/18- 24.0in 3.0in
Old Aug 1, 2007 | 04:53 PM
AntiVenom7's Avatar
Wouldn't Go If U Paid Me
there is plenty of room in the back for a 285-35 if you wanna run it(depending on your how low you are), but the overall diameter is about an 1 larger than stock. not a big deal in my opinion, but others will disagree. a larger tire actually helps put power to the ground from take off(both the larger diameter, and somewhat more forgiving sidewall), but "hurts" you one the top end. it'll also give you ever so slightly better gas mileage, the amount is negligible, for the most part.
the difference in overall diameter of the a 275 to a 285 both in 35series is gonna be 3/10"
http://www.miata.net/garage/tirecalc.html
Old Aug 2, 2007 | 01:33 AM
OK, I ended up using the 265/35-18 in front. I had to cut the lip off, not just roll it. In the rear I am using the 295/35-18 tires that came with my slightly used WedsSports from a forum member. I'll say I might have got away with just a fender roll in the rrar as well I ended up cutting the rear lip off too just like the front. Here's a good pic.
Old Aug 2, 2007 | 08:26 AM
AntiVenom7's Avatar
^^^^what's the offset?
Old Aug 2, 2007 | 09:56 AM
You must have skipped the very first post. Offsets all around are +44mm.
Old Aug 2, 2007 | 12:29 PM
holy crap those tires look HUGE... how much power are you running that you need those monsters?
Old Aug 2, 2007 | 12:49 PM
cabaynes's Avatar
Old and grumpy
you bastard, i wanted to buy those wheels.
cabaynes's Avatar
Old and grumpy
and those 295's look wayyy too big. Switch to some 285/30's
Old Aug 2, 2007 | 01:18 PM
AntiVenom7's Avatar
no, i read it but didn't look at the poster's name. i am sure we have all done dumber things in life.
