Brakes
Old Apr 2, 2002 | 06:16 PM
tmak26b's Avatar
Brakes
I am going to replace most of my brake component. I just need a few info on it.
I am going to replace the master cylinder, my front calipers, front rear rotors, front rear pads and s-s brake lines.
Anyway I got a question on what i need to do first?
I know I havce to bench bleed and install the master cylinder first. TheN I moved to the right rear wheel. At that point do I just remove the brake line and replace it and bleed that wheel there? Then I would move onto LR, RF and LF. After I replace all the brake lines and bleed each wheel. Do I have to bleed the whole thing again or am i all set? Thanks
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
