n/a
Old Jul 12, 2007 | 11:33 PM
Spoonman's Avatar
n/a
i got an 87 rx7 n/a... what all upgrades should i do to the motor to get big horsepower??
Old Jul 13, 2007 | 12:47 AM
dreadseb's Avatar
I think they're hinting the search function at the top of the forum, this has been covered at least twice in the past 4 days.
Old Jul 13, 2007 | 12:49 AM
micah's Avatar
Winter sucks
Old Jul 13, 2007 | 06:23 AM
capn's Avatar
Mechanical Engineering
drop a V8 in for "big" horsepower
Old Jul 13, 2007 | 07:21 AM
pfsantos's Avatar
(blank)
I love the humor in this crowd. Yes, search, but focus on reliability first - do your tune-ups, replace any vacuum lines, coolant hoses, Mazda thermostat/cap, make sure your 6PI system is working, fix that exhaust leack (jk), etc.
Old Jul 13, 2007 | 08:51 AM
jgrts20's Avatar
Who are you?
"Search", but the only thing you really can do with a N/A for power is exhaust and air intake. Youll be lucky if you get 200 HP out of a N/A.
Chris
Old Jul 13, 2007 | 09:16 AM
pfsantos's Avatar
(blank)
Chris
<Sarcasm on> If you mean by "exhaust and air intake" turboing, then 200 hp is reasonable.
<Sarcasm off> To get 200 hp out of an NA involves much more than just a cold air intake (assuming it's one that really gets cold air and isn't in the engine bay) and an exhaust.
Old Jul 13, 2007 | 10:56 AM
Aaron Cake's Avatar
Engine, Not Motor
There is a thread in the Archives called "how to make a beefy n/a". Start there, then search on anything you have specific questions about.
Old Jul 13, 2007 | 11:05 AM
Richter12x2's Avatar
Taste great, more filling
And please - na is non-aspirated, n/a means Not Applicable, which is a little insulting to us NA RX7 drivers, if you think about it (but many TII drivers would argue more accurate.)
Old Jul 13, 2007 | 11:32 AM
shpaintball's Avatar
rotary makes huge gains w/ simple mods ....thats y people love them start outside the motor ....exhaust, intake, ignition,driveline ,ect
Old Jul 13, 2007 | 08:30 PM
RotaMan99's Avatar
Over 200 can be reached with porting after the correct bolt on mods, fuel and timing tuning.
Old Jul 13, 2007 | 09:09 PM
MidnightOwl's Avatar
2 Rotors, 1 Turbo
Ignore the V8 trolls, and port your *****. Bridgeport it and make it sound like a tractor.
Old Jul 13, 2007 | 09:24 PM
RB_eater's Avatar
Leah Dizon > Roast Beef
The correct term is naturally aspirated. Non-aspirated doesn't make sense.
The only way to make a "lot" power out of a non-turbo engine would be to p-port it (plus the obvious mods like exhaust of course). Mazda made 700hp out of a 4 rotors n/a engine so I'm guessing 300hp to the flywheel would be possible with a 13B. Good luck though.
Old Jul 13, 2007 | 09:30 PM
Sideways7's Avatar
Or normally aspirated.
Basically, a realistic goal for an NA with a healthy streetport is 160 to the wheels. Past that requires a full standalone with a good tune, which should net you around 180-185 at the wheels. To get past that requires tweaking the intake and some luck. 200 is about the absolute max attainable with radical porting. With a bridge you can get 250-260 and a PP can get you over 300, but they aren't exactly what I would consider "streetable" cars. And no, the fact that you can drive them on the street doesn't make them streetable.
Old Jul 13, 2007 | 09:32 PM
capn's Avatar
you wish I were a troll!
he asked for big NA power so I say V8!
Old Jul 14, 2007 | 09:35 AM
ericgrau's Avatar
Clean.
Full Racing Beat exhaust or: mufflers (any brand), air pump activated 5th and 6th ports, then (only after you take care of the 5th & 6th ports) a performance catalytic converter. That's step 2. Step 1 is do all maintenance items. Now go search for the rest.
rxlevi7
Sep 26, 2015 07:28 AM
mulcryant
Sep 9, 2015 05:24 PM
